Question about SanDisk Sansa Clip MP3 Player
I have a 4 gb sansa clip and when i try to put music on it it wont let me and says memory full but i deleted all the music i used to have nd it still says free 90 mb when i turn it on
  • SanDisk Master
  • 7,482 Answers
Try this solution for deleting the music
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Posted on Apr 08, 2011
I have down loaded a bea to delete other songs -also I have one auto book I am not able to delete
What is a 'bea?'
One way to delete songs (and maybe books) easily is to it through your computer, while the Sansa is tethered;
1) Download the Sansa Clip manual. Here's a link;
http://www.sandisk.com/media/327475/CLIP+_UM_0809_ENG+090309.pdf
2) Put your Sansa in MSC (Mass Storage Class) mode.
Go to Settings, then USB Mode. Select MSC mode.
3) Tether the Sansa to your computer. It will look like a USB flash drive.
4) Delete or add Music, or Books.
You can use Windows Explorer to look through the directories on the Sansa, and delete files directly, as you would on a USB Flash drive.
Special Note on Audio Books--
Get an extra memory card, 4 to 8 Gb should do, and use this as your destination for audio books. If you have a book that will not delete, you can pull the card and re-format it, while leaving your songs intact on the main memory.
If you cannot delete the book through the computer or by menus on the Sansa, you may have to re-format your main memory. Hope that helps!
Nov 17, 2011 | SanDisk Sansa Clip MP3 Player
How do I delete 30mbs from my sansa clip the message is: not enough space for music DB. Please free 30mbs
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
May 21, 2010 | SanDisk Sansa Clip MP3 Player
How do I get the downloaded music from my computer into the clip?
You have 2 ways to transfer your songs from your computer to your sansa clip:
1. Plug sansa clip to computer, double click on "Sansa Clip ...GB", double click on "Internal Memory", you will see the file "Music", copy your songs and paste them into Music file of the device.
2. Using Windows Media Player: open windows media player, plug sansa clip into computer, click on Sync tab, select songs that you want to sync, drag and drop song selected into "Sync list" on the right side of the windows media player (you should update wmp11), then click on button Start Sync.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip keeps deleting itself
1. Format your device (save songs before do it).
2. Update new firmware http://forums.sandisk.com/sansa/
3. Resync songs.
Good luck
Nov 04, 2009 | SanDisk Sansa Clip MP3 Player
Two problems 1)My sansa clip shut down on its own and when I turned it back on all files were erased. When plugged into the computer the media player still showed 3/4 of the memory still used on the clip...
Its not usles, you can delete the files while on the computer. After having in plugged in you can access it like a flash drive. Then you can open the music folder and delete as you will. Depending on what kind of files you have on it, its possible that i wont recognize the format of the file. I think though from what you've said that it did work, and then stopped playing songs that worked before. So I don't know what to do about that. I don't use the normal way of loading songs onto my Sansa clip MP# player though. I just dump all of my songs via direct transfer into the music folder in the player itself
Oct 04, 2009 | SanDisk Sansa Clip MP3 Player
Error message on E260 player
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Sansa keeps shutting off/ wont read memory disk
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Jan 17, 2008 | SanDisk Sansa e260 MP3 Player
Music isn't showing up on my computer so I can't delete or update! =S
Using msc mode, use my computer and right click on the drive corresponding to the mp3 player, and select format. That should clean up anything that's causing problems.
As far as the player refreshing every time it starts, this is NORMAL, and it WILL take extra time since you have an additional memory card to scan.
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Deleting
You can manually delete the music thru My Computer. My Computer>Device Name (c250)>Media>Music You can see all of the music by albums and delete what you want. Please add to this question if you need more assistance. Best of Luck.
Sep 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sansa wont work HELP PLZ
Ok, I have a Sansa e250 2.0 BG. I have an extra memory card but w/e thats not part of the problem. So, when I downloaded music, I accidently put more music on the Sansa memory and it made it too full. So now it has to do a system restart everytime I turn it on. Which is really annoying. And then I tried to delete some music so It would stop doing that and I could update it, But it shows up on my computer as there being no music. So theres nothing to delete! But it says the memory is full! HELP!!!!
Mar 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
66 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
