Question about Toshiba 52RV535U LCD TV
Intermittently appearing vertical line -various colors - sometimes solid - sometimes stripe
    Sergeant:
    Champion:
  • 230 Answers
These lines are possibly cause by a failing inverter cables from the graphics device transferring the signal to the LCD panel. Apparently, no easy fix for this unless you can reseat the inverter cables and if it won't work consider replacing them. But, the best thing to do about it is to contact your manufacturer and seek professional assistance to avoid tampering.
Posted on Apr 08, 2011
Samsung TV vertical lines
Hi Paul,
I am sorry. There is nothing you can do about it. It appears to be a defective panel.
May 29, 2015 | Samsung Televison & Video
Vertical rainbow stripes on my GB color
I would say that the screen is causing the lines in a gameboy colour the lines are not the same like it would be in an orginal gameboy the one with the four batteries. Lines in gameboy color are the screen issues then the whole screen would have to be replaced on the GBC then.
May 18, 2013 | Nintendo Game Boy Color Console
I want to run an ethernet cable under my house. I have cat5e wall plugs, blue ethernet cable, and a Krone tool, but no instructions. Looking on line isn't helping. Can you?
Here's a good instructional video on making ethernet cable:
http://www.youtube.com/watch?v=0S6cjJS5y1I&feature=related
One thing to note: the order of the colors doesn't matter, as long as they match exactly on the other side. Also, make sure you alternate between solid colored wires and wires that are striped.
Stripe/Solid/Stripe/Solid/Stripe/Solid/Stripe/Solid etc.
Jul 24, 2010 | Computers & Internet
My iphone's screen is white with vertical stripes
try to restore ur fone manually.
that should work
Dec 29, 2008 | Apple iPhone Smartphone
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
26PF9956/12
if they are stationary vertical lines in picture and consistently appear after warmng up most likely would be a display issue. displays have control boards attached to them that would sometimes cause intermittent lines to come and go but if when these lines appear, they do not go away without powering off and leaving off for awhile and if no video can be seen behind lines the lcd panel would be where the failure is and would have to be replaced to resolve issue
Aug 17, 2008 | Philips 26PF9956 26 in. Television
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Mar 25, 2008 | Xerox Phaser 8550DX Laser Printer
Stripy Boot Up
is it a new graphic card? Sometimes that happens when the graphic card gets overheated and fries up some chips. and sometimes those lines appear when the graphic card has fault in Direct Draw. Try setting your BIOS settings to default. if it doesn't work, i recommend you to take the graphic card to the nearest hardware tech ;)
Oct 16, 2007 | SPARKLE Computer GeForce 6600GT, (128 MB)...
Solid vertical line on JVC 42WV74
umm trying using it more, i had the same exact problem and we started using it more and more it has recently gone away.Check the wires as well (plug them out and back in)
Nov 09, 2006 | JVC PD-42WV74 42 in. Plasma EDTV
Toshiba 52RV535U LCD TV Logo
355 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
