The lamp blinks when power button is pressed - Televison & Video
  • 42 Answers
Chect the manufacturers web site for error codes and go from there, most likely a power supply problem... bad capacators are the bane of most electronic goodies today.
Posted on Apr 08, 2011
Dell m210x unresponsive after replacing lamp. Power button blinks, then when pressed, nothing happens and power light goes solid on.
check the lamp ballast
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
have a nice day!
Jerry,Lampdeng Limited
Mar 19, 2014 | Dell M210X Projector Lamp
I have a Epson lcd projector mp-x3 the lamp light is blinking so I replaced the lamp and the lamp light is still blinking and there is no light do I need to reset the lamp if so How do I do thatMukrray
Connect the power cable, power on the projector and then press the [Menu] button on the remote control. The configuration menu will be displayed.
Select Reset Lamp Timer from the About menu, and then either press the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
Select Yes, and then press either the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
The lamp operating time will then be reset.
Aug 11, 2011 | Epson EMP-X3 LCD Projector
I get a 'the ink absorber is almost full' message. how do i fix it. thx in advance
1. power OFF the printer, covers closed.
2. Hold down Resume button, press and hold Power button; Green lamp will light.
3. Still holding down Power release Resume.
4. Press Resume twice, release both Power & Resume and wait until lamp stops blinking.
5. When light is steady, press Resume four times; the indicator should be green.
6. Press Resume once.
7. Press Power to reset.
Jul 02, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
No power to tv. When i press the power button i only get a blinking green light then it stops and the blinking red light for lamp flashes and keeps flashing
You need to replace your lamp. Also check power supply and ballast board. Most of the time if you replace the lamp it will come back up. After replacing the lamp you will need original remote to reset lamp hours.
Jan 24, 2011 | Sony KDS55A2000 55" HDTV
Lamp will not come on. Press power button, fan
You might not be getting power from the ballast, it may be gone.The ballast is what gives the lamp it's major charge of high power.
Oct 24, 2009 | Sony CPJ D500 Multimedia Projector
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
JVC HD-ILA Projection TV
From the manual...
The POWER LED
and LAMP LED are
blinking
alternately.
• It may be a malfunction that the fan is locked or the temperature has increased.
The POWER LED
and LAMP LED are
blinking rapidly
simultaneously.
• The lamp may not have been installed correctly, or it may be due to a malfunction.
• The lamp door may not be closed correctly.
The LAMP LED
continues blinking
• It may be a malfunction of the internal electrical circuits
Feb 16, 2008 | Televison & Video
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
