I have a HP G60-243DX PC Notebook and the backlight turns off when the computer is on. I can see everything in the background but it's just dark. I close the screen and open it again and it turns on for a couple of minutes but then it turns off again. What can be the issue??
  • 32,281 Answers
This could be a faulty inverter.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Apr 08, 2011
How to fix broken TFT background lighting?
I tougth it is better if you replace your TFT in one package. Too much time to be cost if you try to fix the backlight. But you can try this video http://www.youtube.com/watch?v=w4v20PyomuU after you sure that your backlight is the problem by installing another undefected TFT
Aug 15, 2014 | Samsung R65 Notebook
Im a user of Laptop nc6230 for long time , not i found a problem with my laptop. Same time when i switched on the laptop, i can hear everything sound,fan but the screen remain blank. And some time it...
@rashid386
If you turn the computer ON and you can hear that something's running on the background but there's no display , this is a sign that the screen's FL Inverter (this is the chip that controls the backlight of your LCD) or the LCD screen itself is already wearing out and needs to be replaced. If you can see a background image but there's no backlight - you need to have the FL Inverter replaced. If the screen is all black, you may need to have the LCD screen replaced. If you know your way around the computer, you could order screen replacement here and disassembly guide here.
Good luck.
Sep 11, 2011 | HP Compaq nc6230 Notebook
I have a HP G60-243DX PC Notebook and the backlight turns off when the computer is on. I can see everything in the background but it's just dark. I close the screen and open it again and it turns on for a...
Apr 08, 2011 | HP G60 Notebook
HP dv9000 getting power but dark monitor
It is probably that the inverter or the backlights have packed up
Turn the machine so that a strong light shines on the screen from the side you may then see the windows splash screen in the background.
Other check is to plug another monitor into the port on the laptop if that works then it is down to the inverter
Dec 25, 2009 | HP Pavilion dv9000z Notebook
My screen is dark when the computer logs on (but I
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness.
Sep 24, 2009 | HP Compaq nx9030 Notebook
Laptop screen doesnt turn on
when you bootup all the way put a flashlight point it at the screen.
Do you see anything in the background?
Some people see shadows.
Basically it looks like the backlights do not work.
Sometimes inverters can go in which all you need to do is buy a new inverter and install it.
Let me know either way
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Display went dark
The backlighting is provided via the LCD inverter as you described.
Dec 08, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion, Screen working, but extremely dark!
As per your description, I find that the issue is with the LCD Backlight which is also called as LCD Inverter which lights up the LCD to show us the Display on the LCD Display.
If this Backlight is gone bad, you will be barely able to see the Display on the LCD.
Coming to the Noise you had mentioned above can be from the Cooling fans of the Notebook which will be spinning at high speed when the Notebook starts and will reduce gradually after few minutes.
I recommend you to try cleaning the Cooling fan vents using any Vacuum Cleaner or Air Blower.
I recommend you to contact any nearest HP Authorized Service Center and get the LCD Backlight replaced.
Hope this helps....
Jul 21, 2008 | HP Pavilion dv6000z Notebook
My screen went dark !
hello sir
To state the obvious, make sure the brightness is turned up. This is usually a function key on the keyboard. If this doesn't accomplish anything, then the backlight on the lcd may be damaged, and the lcd will have to be replaced.
thank you
Jun 17, 2008 | HP Pavilion dv6000z Notebook
Screen is dark
It would seem that your backlight is not turning on.
First check to see if the switch that detects that the lid closed is working. I am not sure where it is on this model, but all notebooks have one. If it gets stuck, the backlight stays off.
If it is not the switch, it may be the flourescent backlight
tubes or the inverter, It's not an easy fix, but you can check back here.
May 31, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
