Question about Nikon COOLPIX L4 Digital Camera
I am getting the message-Warning! Battery exhausted! although I have installed 3 different sets of fresh batteries.
  • blbridg Apr 10, 2011
    Unfortunately this solution did not work.
  • 10,865 Answers
Hello blb... sometimes this problem is caused by corrosion. Remove the batteries and then use the eraser end of a new pencil to clean the battery contacts within the camera battery compartment. Once you have scrubbed them all clean, use a vacuum cleaner to remove any debris before you reinsert the batteries. Joe
Thanks for choosing Fixya!
Posted on Apr 11, 2011
  • 10,515 Answers
Unfortunately what you have described indicates that there is a problem with the main circuit board it is not getting the power supply properly may be the battery contacts are defective please check them and bent the battery lever up a bit for contact but do it if you are confident as some little force can break them and please follow the steps below..................
1. Remove the battery and memory card from the camera.
2. Let the camera sit with the battery and memory card removed
for approximately 20 minutes.
3. Clean your battery contacts with a clean cloth.
4. Reinstall the battery and power on the camera. If your camera still
doesn't turn on, unfortunately, your camera will require service to
correct the problem. I apologize for this inconvenience.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 08, 2011
I'm one of many who have had problems with the battery exhausted signal one gets with Nikon cameras, even sometimes with freshly charged batteries.
Yes. It sure could have caused the problem. You didn't say which Nikon camera you have, so consider this a general answer. NMH (Nickel Metal Hydride) batteries are rechargeable and alkaline batteries are not. When your camera is set for rechargeable, the recharging circuit is activated when your camera is plugged into the wall outlet. When the camera is set to alkaline, the charging circuit is disabled. Therefore, if you had the camera set to alkaline and you used rechargeable batteries, you batteries were never getting charged. Since your NMH batteries were in a discharged state, your camera gave you correct information.
Jan 01, 2017 | Nikon Cameras
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
Nikon 7600 Battery Exhausted
There is a menu item on the camera to select what kind of battery (Li-Ion, NMh, or Alkaline) is being used. I strongly recommend the use of a rechargeable cr-v3 battery in this camera. There is also a reset function for the battery indicator.
Apr 22, 2010 | Nikon Coolpix 3200 Digital Camera
Put in fresh batteries and camera telling me WARNING!! BATTERY EXHAUSTED
Either the fresh batteries are bad (this can happen), or they were inserted improperly, or the camera is defective somewhere. Measure the voltage on the batteries with a multimeter (voltmeter). Alkaline (regular) AA batteries measure about 1.6v to about 1.5v when new. NiMH (rechargeable) measure about 1.24v when fully charged. Be sure to install them with the + terminal and the - treminal going in the right direction. There should be some indication of this in the battery compartment of the camera. Hope this helps.
Nov 10, 2009 | Nikon Coolpix 3200 Digital Camera
Battery Message
Method 1: Try different ports. Method 2: Install fresh batteries. Method 3: Resynchronize your device to the receiver. Method 4: Install the latest software from this website: http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx
and Method 5: Clean the mouse lens.
Oct 21, 2008 | Microsoft Wireless Laser Mouse 5000
BATTERY EXHAUSTED
Make sure you have the internal menu for the battery selection correct.
Choosing the wrong battery may cause this.
Rechargeable batteries and alkaline batteries are not the same.
This may also be a condition and problem caused by the camera itself, and may need repair.
Sep 08, 2008 | Nikon COOLPIX L3 Digital Camera
Battery exhausted warning
Hello justplainles:
Do the others show the same problem?
Try this: RESET ALL in the menu or setup menu.
If that does not work, make sure that the in the menu (if it is there) you set the battery type to rechargeable not alkaline .
You may try alkaline batteries, if it does the same, the camera may need repair.
Some cameras will not set the battery type automatically.
Aug 25, 2008 | GE A730 Digital Camera
Battery/Camera dies?
Go to the menu and make sure you have the battery type set to the kind you are using.
Battery EXTREMELY Exhausted
You MUST use rechargeable batteries , like NiMh , with charger for that kind of battery , and your problem will go ...
May 25, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
