Question about Garden
I ve a C230 Shindaiwa br cutter. Need holder B fo blade assy. Holder B sits on the gearcase shaft. I am in Brisbane; where can I get one ?
  • 710 Answers
Your part number is: 22410-13251
You can find it online at: http://www.ereplacementparts.com/holderb-p-504060.html
Or you can find it here: http://www.partstree.com/parts/?pn=22410-13251
I have found ereplacementparts to be very slow with delivery. I'd start with partstree.
Is Brisbane in Australia, New Zealand, or Canada?
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 08, 2011
I have a Dewalt DW321 corded jig saw. I can't get the blade to release. The blade blade holder seem frozen.
place the shaft in the fully up position and give the collet holder a tap to move it back up further
sometimes they jam from metal, dust and grit
sometimes a bit of WD-40 or like item will lubricate the movement and make it easy to pull up
Nov 18, 2017 | Dewalt Saws
If you take off the blade holder on a craftsman lawn holder can you mount the blade to the shaft?
Probably not, the blade holder will have the mounting / drive pin(s).
Jun 05, 2017 | Craftsman Garden
Replacing spool holder
If you search online for:
Make + Model + "replacement parts"
you may find a replacement. Otherwise, you can usually manufacture a spool holder using a drinking straw, wooden skewer, or something similar. There are also standalone spool holders for sale at various web sites. The spool holder doesn't necessarily have to be attached to your machine but can set behind or to the side of it. Some sewists throw the thread spool in a big coffee cup and just let it bounce around in there.
Jul 29, 2016 | Sewing Machines
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Mar 18, 2011 | Brother HL 5250DN Laser Printer
We own a Dewalt DW735 13" planer. Have lost or misplaced the owner's manual. We need to reverse the knives for the first time, and do not know how to do it.
Unplug the machine then crank open the head up as far as it will go. Underneath, in the middle of the head you'll find two feed rollers and a cutter head with the blades on it. Even dull the blades are very sharp so work carefully. Each blade is held in place by a blade holder and eight allen screws. Remove all eight allen screws and the holder and blade will fall out. If they have excessive sawdust or tree goo on them they may need a bump from the plastic end of a screw driver to knock them loose. Keep track of how they come off so you can put them back on the same way only with the blade turned around. The top of the blade holder will fit into a channel in the blade so they'll all go back in lined up correctly. Turn the cutter head carefully to get at the other blade(s) to change them.
Nov 15, 2010 | Garden
Thickness Planer (DW733) leaves fine scratches on wood surface.
It sounds like your blade holder assy has become misaligned on the blade drive shaft. Try if you can to use a straight edge on 2 planes 90 deg apart and see if there are any gaps in either of the srtaight edges. I suspect that the blade drive holder has become slightly dislodged from the drive collar on one end allowing the blade drive to tilt on the drive shaft. I had the same thing happen on another brand named Planer and it was a matter of reseating the collar to cure the stripes. Sure took a long time to sort out. Good Luck.
Feb 06, 2010 | Dewalt DW735R Reconditioned Heavy Duty 13"...
No running manual 4 summasign pro D610 vynal cutter
You can get assistance and possibly a manual for your Vinyl Cutter from a Summagraphics Repair facility such as
ADVANCED GRAPHICS
1027 N. MAIN STREET
TEL: 210-227-9393
SAN ANTONIO, TX 78212
I hope this helps. Toni Gallucci, Glass Act
Mar 17, 2009 | Computers & Internet
Bravetti Food Processer
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us toll-free at 1-800-798-7398. Hours are Monday through Saturday from 9:00am to 6:00pm Eastern Standard Time.
Jun 30, 2008 | Bravetti Quad Blade Food Processor
Need part# for cutter assy
part# ACC-230kit Cutter assy for 1000 or 1000 II
Agson 856-751-9048
Oct 07, 2007 | Citizen CBM 1000 thermal Printer
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
