Question about Pioneer XM2go Inno Satellite Radio Receiver
Hello, I have a Pioneer Inno (model GEX-INNO2 a few days ago I noticed the display is not correct for exmaple channel 41 should be Hair Nation but it says Boneyard.When I listen to channel 41, it is Hair Nation .I called Xm they resent the signal but no good!!!They told me to call Pioneer so I did.They said that it is not on their end, maybe you can give me so kind of direction?? Thanks for you time
4 Suggested Answers
SOURCE: No XM Audio, no fault indication
Buss cable is plugged into the wrong connector on the GEX-P920XM. The installation manual is not clearly written, the figure in the manual is correct.
Posted on Feb 25, 2007
  • 11 Answers
SOURCE: Pioneer GEX-INNO2BK XM Radio Receivers backight problem
Have you tried changing the backlight controls in the menu? Pull up your menu, go to settings, then preference, and change display. Choose backlight display. You can put it always off, always on, or on for however many seconds.
Posted on Jun 11, 2010
  • 11 Answers
SOURCE: pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
Does pioneer have a car cradle for the inno2 that secures it better i have gone through so many of them and now my warranty is up. i operate heavy equipment and it causes my inno to fly out of the cradle,...
I feel your pain. Unfortunately, I haven't been able to find any car docks, there all discontinued. (sorry bums!)
But, when I'm riding my motorcycle, I put a rubber band around the radio and dock, holding it in place.
But, in a place that doesn't interfere with any buttons or the display.
Jun 06, 2010 | Pioneer inno2 Portable XM Satellite Radio...
Pioneer Inno - Powers on, great signal - but audio or pad data!
I'm assuming the power button it not in 'hold' position, and you have the volume turned up, and/or on the correct frequency with the adjoining radio?
May 27, 2010 | Pioneer XM2go Inno Satellite Radio...
My pioneer inno xm receiver is stuck on channel 1 and 234. have had xm reactivate my signal 3x since early this am. still cannot move to other stations, pioneer is closed for the weekend and the manual...
It sounds like the radio is not activated. If it isn't, go to xmradio.com and follow the instructions to activate it. If you have activated it, and you are still getting only two channels, either go to xmradio.com or call them and you can "refresh" the activation.
Feb 13, 2010 | Pioneer inno2 Portable XM Satellite Radio...
Inno will not work in car have good reception and no function on the inno for frequency, but can listen through headphones. external antenna is hook up also
Are you using a car dock with the sure connect wiring system, or an mp3 patch cord from the Inno to your auto radio with aux. input?
Jan 24, 2010 | Pioneer inno2 Portable XM Satellite Radio...
Volume control
Remove the back battery cover only. Turn unit on. Insert a tiny paperclip thru the tiny 'reset' hole on the back of the unit inside the battery compartment. OK?
Aug 05, 2009 | Pioneer XM2go Inno Satellite Radio...
Screen won't flip when in the cradle
Take it back the store where you bought it at. It sounds like a broken system?
Jan 09, 2009 | Pioneer inno2 Portable XM Satellite Radio...
Pioneer inno
Have to use a car dock to use the fm transmitter.
Sep 29, 2008 | Pioneer inno2 Portable XM Satellite Radio...
Pioneer Inno Gex-INNO2BK stuck in re-boot cycle
I fixed the reboot cycleing problem by plugging the travel charger into the jack that also fits the home and car cradle. I had the Inno set to auto start when it was powered on in the car cradle. The travel plug must have over-ridden the auto-start setting and allowed it to finish the complete bootup. I then reset the Inno default settings and every thing was back to normal. I do not know what was the original cause of the rebooting cycle problem
Jul 28, 2008 | Pioneer inno2 Portable XM Satellite Radio...
127 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
