Question about Keurig B60 Coffee Maker
Grounds are coming out and into my coffee. - Keurig B60 Coffee Maker
  • Keurig Master
  • 43,501 Answers
Bottom needle is plugged...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 08, 2011
Ground coffee is like mud
the coffee is too fine.Fix it from coffee beans section
Nov 05, 2013 | Saeco Incanto Sirius Fully Automatic...
The problem is when I use pre ground coffee beans. The water doesn't run through. It comes over the top and the grounds get in the coffee. I buy them that way because they mark them down half price. I
There are whole coffee beans, and there are ground coffee beans, but there is no such thing as "pre-ground" coffee beans because you wouldn't want the beans to be ground AFTER making coffee.
If you have a problem using "pre-ground" beans, then STOP using pre-ground beans and grind them yourself.
I hope this helps.
Randy
Dec 01, 2012 | Coffee Makers & Espresso Machines
My Coffee Gaggia Vision is grinding and the coffee is coming out very weak. The billet coming out is very wet and small. Any solutions or ideas?
see this matter causes:
Make sure there's water in the unit's water tank.
  • 2 Unscrew the shower disk from the top of the unit and rinse it. Dry the disk and screw it back in place.
  • 3 Replace the coffee grounds with properly ground beans. Coffee beans that are either too finely or too coarsely ground will adversely affect the flow of coffee from the machine.
  • 4 Make sure the coffee in the filter is not packed too firmly if the coffee isn't flowing at all. If the flow is too fast, tamp the coffee down a bit more with the tamper.
  • God bless you
    Jul 18, 2012 | Gaggia 90950 Platinum Vision Espresso...
    I need to clean my capresso c1000. i can't find the instructions. i put a cleaning tablet into the ground coffee area, and ran the ground coffee button a few times. is that it?
    No, first push the self clean button (hold until lights come on). Then pull the grounds unit and empty it, that will turn off one red light. Fill the water tank. Then drop the tablet. Then hit the ground coffee button. Cycle through and dump the grounds each time the grounds light illuminates.
    Jul 09, 2011 | Jura Capresso C1000 Espresso & Coffee...
    When i make a cup of coffee with my kuerig coffee maker my coffee is coming out with coffee grinds though it. how can i fix this problem?
    Your coffe may be ground too finely for your maker.
    Is your coffee maker flat-bottom or cone shaped? Or is it a french press?
    Your coffee needs to be ground according to the brewing method. Too coarse and it will be watery, too fine and it will be too dark, or you might get grounds.
    May 06, 2011 | Vacuums
    There is no water coming out of the machine at all. No error light come on but when you go to make a coffee with beans or pre ground it goes through the process but just dry coffee comes out. Also no water...
    For the steam check the end of the nozzle to make sure it is not blocked.
    For the coffee run a coffee using the pre ground method but without coffee grounds, if water comes out then grinder is too fine, if no water remove brew unit and clean top shower screen, you might have to clean tube leaving from shower to discharge.
    Aug 29, 2010 | Gaggia Syncrony Compact Coffee...
    COFFEE GROUNDS COME THROUGH THE HOLES IN COFFEE BASKET. WHAT TYPE COFFE SHOULD I USE TO ELIMINATE THIS? IS THEIR A FILTER MADE FOR TJHIS URN
    Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
    Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
    Amount of coffee to use
    This is from the FAQ section of West Bend's website at www.focuselectrics.com:
    As a guideline, use the following amounts of ground coffee for the number of cups being prepared. Use standard measuring cups ( as used to measure flour, sugar, etc.) to measure the coffee. The amounts of coffee below will brew mild to medium strength coffee which most people prefer. The amount of coffee can be adjusted to suit personal preference. As a guide, there are about 5 cups of coffee to a pound (16 ounces).
  • 12 - 18 Cups Coffee = 1 - 1 1/4 Cups Grounds
  • 20 - 25 Cups Coffee = 1 1/4 - 1 1/2 Cups Grounds
  • 28 - 36 Cups Coffee = 1 1/2 - 2 Cups Grounds
  • 40 - 45 Cups Coffee = 2 - 2 1/2 Cups Grounds
  • 50 - 60 Cups Coffee = 3 - 4 Cups Grounds
  • 70 - 80 Cups Coffee = 4 1/2 - 5 Cups Grounds
  • 90 - 100 Cups Coffee = 5 1/2 - 6 1/4 Cups Grounds
  • Hope this helps. You might also be able to download the manual from there if you look for your model.
    Sep 23, 2008 | West Bend 13500 Coffee Maker
    No coffee
    Make sure the water pipe not is broken.
    If you take out the brewing unit and look at the chassis on the machine, you can see a hole, there should be a little plastic pipe comming from the machine down to the hole. If this is broken then the water will go to the driptray.
    /Mirran
    Aug 14, 2008 | Saeco Vienna De Luxe Espresso Machine
    Keurig B60 Coffee Maker Logo
    129 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Oloyede Monsuru
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
