Question about Dell Dimension 4700C PC Desktop
I have dell dimension 4700c I just get black screen all diagnostic light are green there are on beeps I have try F2,F8,F12,Windows turn it on take power cord out nothing is working pleas ehelp
  • Daniel Wakefield
    Daniel Wakefield Apr 08, 2011
    Just to be clear. You get nothing on the screen at any time? No words or pictures ever? But the lights still work on the monitor?
    Sergeant:
  • 189 Answers
You should try a different monitor if you can. I can't tell if you see the motherboard's BIOS, but if you don't, then I bet it's the monitor. If you can't find another monitor to plug it into, your TV might have the correct input. Hope this helps!
Posted on Apr 08, 2011
  • 42 Answers
Check out Dell website, support for beep codes.
Dell 3000 beeps twice no video after blue dell logo.
The most possible cause is that RAM isnt attached properly on motherboard, it might loosen up sometimes. So just try to check your motherboard, pull out the RAM carefully from the RAM SLOT & attach it precisely. Hope it will work....
Feb 29, 2012 | Dell Dimension 3000 PC Desktop
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
I clicked the turn off computer and it it shut down, now it will not restart ?
Make sure all the plugs are well seated, especially the power plug for the computer and monitor, and the video cable between the computer and monitor. Also check the power strip the computer is plugged into to see if it's tripped.
Mar 03, 2011 | Dell Dimension 3000 PC Desktop
On powerup of Dell Dimension 5100 running Windows XP the computer hangs with diagnostic lights 1, 2 and 3 a steady green and 4 off. The onscreen message is: 300XT BIOS P.N 113-A33437-102 which appears on a...
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Nov 05, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Trouble booting past the BIOS Screen
Remove the cmos battery and unplug comptuer for about 15 to 20 minutes. install battery working battery. make sure you didn't knock any cables loose
Check ram is seated
Check video and audio cards are seated properly
Then try booting pc.
Jan 22, 2009 | Dell Inspiron 6000 Notebook
NO VIDEO ON DELL INSPIRON 1501!!! PLS HELP ME!!!
ok
when u power up the paltop press F8 key then go to last known good configuratuion if probelm remains same then chosse safe mode then remove your network driver from it.
also try to rest your defauls sdetting in bios .
when u power yup the laptop press del or F2 or F5 to F12 try this key one by one.
then go to load defauls settitngs then save that settings.
also check in enable vga mode when u press F8 key at power up.go to enable vga mode tthen settings of disaply porperties.800*600 or 1024 *768.
Nov 10, 2008 | Computers & Internet
Dell Dimension 4700C PC Desktop Logo
123 people viewed this question
Alun Cox
