Question about Samsung Digimax S630 Digital Camera
I accidently erased my memery card. When I went to take pictures using the memory card the camera reads "card error". How can I reuse the memory card?
    Problem Solver:
  • 19 Answers
Follow the instructions on this site to reformat an sd card
http://www.ehow.com/how_4793481_reformat-sd-card.html
It is common for cheap SD cards to develop problems over time you may need a new card
Posted on Apr 08, 2011
Will pictures remain sharp when a smart card is reused several times?
No. images are stored digitally, so a one bit remains a one, while a zero remains a zero. The card will wear out eventually, after hundreds of thousands of write cycles, but that's after decades of normal use.
More importantly, you want to format the card regularly, like after each time you download pictures to a computer. If you simply delete the pictures each time, you're all but guaranteed to have a file system error eventually. Formatting avoids this.
Mar 04, 2012 | Nikon Cameras
Dsc h70 sony - I encoutered this message after I inserted the memory card to the camera "image database file error cannot recover" If I take out the memory card and put in a computer, I can...
You need to format the card IN YOUR CAMERA using the camera's format feature (look for it in the menus). Make sure that you save all the enclosed pictures onto your computer first as formattin will erase the card.
Sep 10, 2011 | Sony Cyber-Shot DSC-H70 Digital Camera
I am getting a "Memory
Its a very common problem with S400,S410 and some others.
As a case study, see the following error message on the Canon IXUS 130 when trying to view some photos previously stored in the memory card SDHC
"Memory Card Error"
Every single photo stored on the memory card becomes inaccessible after the above error message. In addition, no more photos can be stored on the memory card. In short, the card can not be read or written.
Cause:
The above error message that makes all the pictures inaccessible is mainly caused due to corruption of the memory card. Reasons why you are responsible for the above error message is virus infection, interrupted read / write operation, and human error.
Resolution:
The resolution for the above error message is the format of memory card into the camera. The process erases all data previously stored and allows you to save the new data. While the format is a good resolution for users who do not require the old data, it is fatal to users such as photographers, detective agencies, etc, to save critical data on your memory card. However, the formatted data recovery day is now an easy process. It is therefore necessary to use an advanced part of third parties. A tool for image recovery is readily available on the Internet by one click.
Data Recovery is an application of high-end recovery that recovers data from almost all formats SDHC Card, XD and MMC. The read-only photo recovery tool also allows you to restore data in the defined location. The software runs on Mac OS X and Windows.
Check this link for additional details: Simple Fixes for SD "Memory Card Locked" or "Memory Card Error"
Hope helps.
Jun 07, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
I received the "clean or
Welcome to FixYa.
I have seen several question with the same issues on your camera. There where 3 possible reasons why do you received an error "clean or format card". First reason is your card was not formatted for the camera used. You need to format it first for you to be able to used the memory card. Second reason is memory card slot or the memory card itself requires cleaning. Yu can used soft and dry cloth to cleaned it, sometimes pencil eraser or any eraser can be used to clean the memory card, but you have to be careful in using it on your memory card. After you clean it, you also need to format the memory card. Third possible reason is memory card might need to replace.
Notes: All existing data, including protected pictures, are erased when internalmemory or card is formatted. Make sure that you save or transfer important data to a computer before formatting the memory or card.
Make sure that there is no card inserted in the camera when formatting the Internal Memory.
be sure that the card is inserted when formatting the Memory card.
Make sure that you have a fully charged battery or used the AC adapter.
I hope this information can help you.
Thank you for using FixYa.
Apr 04, 2011 | Cameras
Cannon SD1100 IS Digital Camera The Camera reads " Card Locked". The Maual's solution is to slide the switch up on the memory card. Did that still won't work. When I go to the Menu, the...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Feb 25, 2011 | Canon PowerShot SD1100 IS Digital Camera
I'm getting a no memery card error
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 28, 2010 | Canon PowerShot SD960 IS Digital Camera
My samsung BL103 was taking black and white pictures. I was trying to get it back to color. I went to settings hit format, said yes or no? I hit yes and now have no pictures on my memery card. Can those...
Format completely erase the memory card with no hope of recovery. You need to dust off your manual and read it to find the correct setting for color pics.
Oct 26, 2010 | Samsung BL103 Digital Camera
Does "memory card full" mean you have to purchase another for canon powershot sd750 or can you erase?
You can either erase the pictures or transfer them to a computer using the supplied USB cable or remove the flash memory and insert directly into the computer's sd card port.
Sep 08, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Nikon Coolpix 4600 Digital Camera
Picture card
You can buy a cheap multi card reader at an office supply store, Best Buy, a computer store or a photographic supply. Use the card reader to read your memory card from your computer
Feb 15, 2008 | Fuji FinePix 1400 Zoom Digital Camera
Samsung Digimax S630 Digital Camera Logo
107 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
