Question about Frigidaire GLTF2940ES Front Load Washer
Drum seems totally unattached in the washer machine?!?!
  • Frigidaire Master
  • 2,605 Answers
Welcome to FixYa
Based on your description I suspect the rear bearing or spider gear is toast. You are probably right, either the suspension shock absorbers are broke or the inner basket is separated from the spider gear often times.
Very common for these machines unfortunately. It isn't too bad if just shocks, but it is a very involved repair for the spider gear/inner basket.
**Unplug the unit from the wall before attempting any of these service tips...safety first**
You'll need to remove the lower access panel to investigate the shocks...these shown are the newer style but previous versions where all plastic, hence the broke much easier.
i.e.
and the rear panel to inspect the basket & spider gear attachment. Check for any signs of leakage or rust behind where the arrow indicates...the tub bearing.
If you think you're up to it I can help in whatever manner possible with those Frigidaire washers.
I'll watch for your reply. Good luck.
Regards,
Macmarkus :)
Posted on Apr 08, 2011
Admiral washer machine tub appears loose and unattached in rrear
First of all is your machine working or not?
If it is working and it's a front loading machine. The machine drum is hanging inside the machine using strong springs that helps it to reduce vibrations during washing and spin cycle.
When machine goes into spin(dry cycle), it usually shakes a little.
Dec 08, 2014 | Admiral Washing Machines
Electrolux washer won't spin
Yes the motor is faulty (Seized bearing(s) ), some motors can be dismantled & bearing purchased from you local bearing store.
Dec 21, 2013 | Electrolux EIFLW55IRR
The drum on my wma 40 seems to go tight any ideas why
may have something stuck between the inner and outer drum...... socks tights and womens skimpies very easily slip down at the bottem door seal.... afraid the machine needs a total strip down if this is the case. remove the door and front panels, the drum has a front cover held on by a number of clips..... remove all clips take cover off....find said item and put back together shouldnt take more than an hour.. if it isnt that,.then rear bearing could be shot at,, sorry
cheers
Mar 24, 2011 | Hotpoint WMA40 Front Load Washer
I have a GE Front load washer model # WHDVH660HWW. Everytime it goes into spin cycle the machine vibrates/shakes and it keeps stopping and then tries to reset. Eventually shutsdown. I ahve to open door...
Sounds like one of the internal suspension/dampening units for the drum unit has broken or become unattached. Am not certain what this machine has but removal of top and rear cover should allow you to inspect the items and arrange replacement as required.
Dec 20, 2010 | GE WSXH208A Front Load Washer
I have a kenmore front load washer model 41744042400 the drum seems to be off its track. it makes a lot of noise when spinning and shakes a lot. One of the shock absorters was broken and i replaced it....
they dont have tracks they sought of float in the middle of the tub held on by the shaft coming off the spider arm on the back of your drum, if you can move the drum back and forth and it makes a metal crunchy kinda noise your spider arm has snapped to fix it you need a new drum and will almost quite literally have to dissasemble the machine into every piece its made of, altho not neccesarily difficult is quite time cosuming about 3-4 hours (thats for someone with experience)
Sep 20, 2010 | Kenmore Front Load Washer
Machine vibrating badly
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Zanussi ZWF1430W Front Load Washer
I need to fit a new door seal
easy fix love what you need to do is un-plug the washer now tak the 2screws from the back of the washer that holds the top(lid) in place now open the door and around the edge of the door seal there will be a spring wire pull this out so you can unattach the door seal totally from the washer front the seal will still be attached to the inner drum though now stand up and look down through the top of the washer down to the front were your door seal is still attached to the washer there will be another clamp with a screw on it undue the screw but you dont have to undue it totally though pull the clamp out through the front through the door seal now will come off the washer now just do these instructions backwards to re-fit the new door seal let me know how you go on or if you get into trouble doing the job peter
Jun 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Drum
u need to put something like a wooden hammer handle into the hole in the spider at the back when u have put it in spin the inner drum clock wise fast so it undos the spider or pulley wheel to some people once the spider is all the way off u need to put the nut back on just so it is level with the spindle with a rubber mallet strike it fast and hard and it will move the inner drum to come out once it comes so far out u need to undo the nut and remove the inner drum totally
Sep 01, 2007 | Hotpoint Ultima WF865 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
521 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
