Question about Sport & Outdoor - Others
Healthrider H70e elliptical will not change resistance- stuck on level 1, I purchased a new resistance motor and when I installed it I could see the motor working and setting the resistance back at 1, and now it will not adjust to any other level again.
  • Bob Crachett
    Bob Crachett Oct 20, 2016
    I have the same issue. Healthrider H70E can not change resistance stuck on position 1. I replaced the resistance motor and touched a resistance level and it seemed to just return to level 1 position. Now the motor will not move again. What is going on?? Where is the problem??
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
taran_2005
  • 10515 Answers
SOURCE: We have a REFLEX Step
I had a similar problem recently with my elliptical - it was permanently stuck in the "hard" position. In my case, it has a wheel that turns when you step, and the tension is adjusted by a pair of magnets inside this wheel assembly. These magnets are positioned near the wheel - closer for more tension or further for less tension.
The console control electronics that send a signal down to this wheel assembly. There is a little motor that pulls on a short cable to position the magnet(s).
The problem was that the cable attached to one of the magnets snapped, leaving that magnet close to the wheel, i.e. high tension. We had to have a technician order and replace the entire wheel assembly as its individual pieces are not made to be serviceable.
It sounds like your case might be similar. Maybe you only have one magnet or two. In any case, I'd look at whether the magnet(s) are moving relative to the wheel when you adjust the tension settings (you should be able to see or hear the magnets move - you might need a buddy to help).
While you may not be able to repair it yourself (you can get yourself pinched badly around these gears and mechanical elements), you will at least know what's going on so you get the right work done if you choose to hire someone.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 01, 2010
ercupa190
  • 12223 Answers
SOURCE: why does the resistance on my elliptical randomly go to OFF while working out
Do this for your console Elliptical:Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replace the left and right disc shields and sideshields. Reattach the ends of the pedals to the crank axles
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Dec 06, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
Posted on Jun 11, 2012
ercupa190
  • 12223 Answers
SOURCE: Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Posted on Aug 30, 2012
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
I have a Proform Hybrid elyptical/incumbent bike and the resistance levels no longer work .How do I repair this?
Hi There ,
There might be a problem with the resistance motor.
Ring Icon Fitness, they are the distributor for this brand world wide.
Sep 10, 2014 | Proform Hybrid Trainer Elliptical And...
No resistance for Healthrider H90E elliptical
More than likely your going to need a console...If you checked all the power from the console down to the resistance motor and that's good then console is bad.
Dec 08, 2013 | HEALTHRIDER H90E Elliptical Console Model...
Resistance
This could be caused by either a bad lower electronic board or the brake/generator. I am attaching a link to the service manual for you for further reference. http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Jun 27, 2013 | Precor EFX 546i Elliptical Version 4
My Healthrider Elliptical H70e is measuring km/hour instead of miles/hour. How did I change this setting and how can I change it back?
there 2 ways: 1) go to back the display board , are small orifice, use the point of erase pencisl. and click the small switch and change the km to miles or vice-versa
2) use the menu, and go to speed how to change the speed.
use your instr. manual if you do not have download free. www.fitness.manualsonline.com
God bless you
Jan 22, 2013 | Exercise & Fitness
God bless you
Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
God bless you
Jun 10, 2012 | Exercise & Fitness
My Schwinn 430 Elliptical is not changing resistance when requested. I hear a noise as though it is trying to change, but it does not. The resistance level is shown as changed on the display. Is this...
I think I am experiencing the same problem and have removed the shrouds. Are you experiencing a clicking sound while the unit is plugged in? All of this seems to deal with the servo motor. Don't be fooled by suggestions to replace the rpm sensor...this is NOT the problem. I am trying to find out what the initial setting for the servo motor and the tension cable should be. I found a site where you can order the servo motor, but it tells me that it could be months to receive this part. Sigh...
Sep 12, 2010 | Schwinn 430 Elliptical Trainer
Just bought my Proform 490 LE elliptical 1 day ago and it has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried...
Mar 13, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Resistance level does not change anymore. What is
I fixed a problem with my Schwinn Elliptical 430 resistance level not working. When I would change the level anywhere from 1-16, I could hear the motor turning, but there was no change in resistance. If you hear the motor moving, then try this:
Using a Phillips screwdriver, remove all the screws on the left side of the large plastic cover (left side if you are standing on the machine). When all screws are removed, you can pull the plastic cover off, and move it towards the back of the machine without having to disconnect any of the metal bars. (The bottom two screws are a little tricky to get off. Hold the housing in place, don't let it sag, in order to get them out.
Look inside the unit and find the magnet, which is a rounded, brake-show like piece that is close to the flywheel, on the top half of the unit. There's a cable from the motor that goes upward and is attached to the magnet housing.
If you try to adjust the resistance level now, you should see cable move up. This is supposed to allow the magnet to move closer to the flywheel and increase resistance. In my case, the magnet was stuck and wouldn't move upwards. When I gave the magnet a little push with a screwdriver, it popped up to where it should be.
To solve this issue, you will need two wrenches. You must go to the opposite end of the magnet, towards the front of the machine, and you will see it's connected with a nut & bolt. Using a couple wrenches, hold the bolt, and loosen the nut about 1/4 turn.
This should lessen the pressure on the magnet housing and allow it to move freely and not bind. Reassemble everything. Lie the elliptical down on it's side to allow the screws to fall into the holes easier.
Once it's all back together, you should find that the resistance level works again!
Sep 23, 2009 | Schwinn 430 Elliptical Trainer
Sport & Outdoor - Others Logo
356 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
