Question about JVC DR-MV1S DVD Recorder/VCR
Cooling fan stays on all night - JVC DR-MV1S DVD Recorder/VCR
You probably have set up one scart as being connected to 'sat' or sat controlled
(I cannot remember the exact setting)
If you do so, the recorder is controlled by the satreceiver, and is 'on' all the time.
Good luck (my DR M10 broke down yesterday - The drive does not recognise dvd-ram disks anymore :( )
Posted on Dec 12, 2008
SOURCE:
P0481 for chevy imapala 03
Possible causes
- Faulty fan control relay
- Faulty cooling fan 2
- Fan control relay harness is open or shorted
- Fan control relay circuit poor electrical connection
- Fan cooling fan harness is open or shorted
- Fan cooling fan circuit poor electrical connection
Jul 07, 2014 | Gentex 2003 Chevy Impala - All Impala...
I have a GE microwave. Beginning last night, the inside light stays on with the door open and when you close the door, the cooling fan starts up and the light stays on. The turntable doesn't rotate an
You have a major electrical issue within the microwave......potential electrical fire hazard. Unplug it and get a new one. Circuit boards are usually the same as the replacement price.
Nov 08, 2012 | Microwave Ovens
Mercedes S430
When you shut the car off something is staying on in the vehicle, causing a current draw on the battery, causing it to go dead over night. something that would cause this would be like a under the hood light, trunk light, interior light staying on. visually check it. and if you don't find anything you might want to buy a fluke/ volt meter, to check for unwanted current draw when the vehicle is off. your local mechanic could help. it could become more extensive then this but most likely not by the sounds of it.
Oct 14, 2012 | Mercedes-Benz Cars & Trucks
To turn on the air conditioner, on the thermostat do you click it to Auto and then on the other side click to Cool? Or do you click on Fan and Cool?
If you put the fan to auto, the fan will run only when the compressor runs. the other position it will run untill you switch it back to auto. Then cool unless you require heat at night or in the morning, usaually when I start cooling season the heat stays off.
Jul 05, 2011 | Honeywell Heating & Cooling
Cooling fan will not go off
Do you mean it will run all night if you let it? The cooling fan can run for quite some time after the car is off and it is normal for it to behave that way, but if it runs all night.....sounds like you need to replace temperature sensor and/or switch.
Dec 04, 2009 | 1991 Toyota MR2
Have 9.3 saab 2lt Low turbo petrol, fan for heater in cab works great but when I stop and turn engine off fan carrys on running? have to remove fuse every night, any ideas please
usually when the fan stays on is for a certain amount of time to allow cooling off the engine but if it goes on and not going off there has to be some kind of a short or another wire allowing that to happen without shutting off
Nov 14, 2009 | 2003 Saab 9-3
Why is my engin cooling fan staying on?
check and replace the engine cooling fan relay, refer to the owners manual for location under the hood.
Sep 27, 2009 | 2004 Mitsubishi Endeavor
1996 Honda Odyssey engine cooling fan stays on.
I don't thing there is a short there is radiator fan switch that control these fan, it works off of heat. There is also a fan relay that control look in fuse box inside the hood for fan relay and make sure its NOT stuck , if it isn't then its the fan switch.This switch may be bad and cause the fan to turn on. Replace radiator fan switch located on water outlet on engine and this should solve your problem. A
May 15, 2009 | 1996 Honda Odyssey
Cooling fans
how long does it stay on?? electric fans have a thermostat and can keep running after your car has been turned off
Sep 19, 2008 | 1991 Toyota Celica
JVC DR-MV1S DVD Recorder/VCR Logo
236 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
