Question about Canon PIXMA MP760 All-In-One InkJet Printer
Canon pixma mp760 is not printing even though all inks are full
  • Canon Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Apr 08, 2011
Canon mp760 printer overflow full, have parts and service manual. Need code to get going again
there is no need to change the ink absorbing sponges at all ,,as i hve solved this problem myself for many of my clients i m sure that it will work for u too if followed properly step by step:
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
reset sequence for a MP760 printer that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
ur printer absorber will reset and will work properly and u will be back to work.try doing it one more time if u miss something .
please take a moment to rate the solution after u get ur problem solved
Oct 03, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Black ink will not print on Pixma mp760
Dec 20, 2011 | Canon PIXMA MP760 All-In-One InkJet...
My Canon pixma mp760 wont print in black. colour printing is ok
Possible that the B&W ink cartridge is faulty or there is poor installation . You need to shut down the printer and remove the ink cartridge. now reinstall after ensuring that printer was disconnected and then connected.
Feb 09, 2011 | Canon PIXMA MP760 All-In-One InkJet...
Canon PIXMA MP760: Waste Ink Absorber almost full - interrupts printing. Removed/cleaned absorbers. Still "almost full". I found out that there is a counter, versus a sensor, that determines the state of...
I'm curious as to how you cleaned the ink absorbers since they are normally sealed.
Go to the Cannon USA website and search using the terms full ink absorbers and MP760.
Let me know if you still cannot find the answer.
Oct 15, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Printing is very very light.
Try Changing The Printer Detail To High Or Auto
Jun 01, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Changed the print head in my Canon MP760 but now printing is blurred and very faint
Try cleaning the felt pads where the print head would rest when not printing. They get full of ink and cause more printing problems. I use water to clean them.Don't loose them, they are needed to keep the print head from drying out.
May 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Streaky printing from canon pixma MP600
There is usually a maintenance button or similar in the "printer properties" dialog box to run a cleaning cycle."Right click" on your printer, select "properties", and you should see something. Try that.
Also, are these Original cartridges or compatibles / refills? Non originals can often cause image quality problems
Mar 01, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Canon MP760 black ink dull and has stripes
Take the cartridges out and also the printhead and set the nozzle of the printhead on a 5-sheet pile of kitchen paper that was make wet in the middle with some lukewarm demineralized water ( water for an iron )there is not much necessary if there are clogged nozzles deep inside the printhead buy cartridge flush different methode for printers to find
How To EASILY Unclog Ink Jet Print Heads
Aug 26, 2017 | Canon PIXMA MP760 All-In-One InkJet...
My Canon PIXMA MP760 printer had been printing a horizontal stripe of a lighter cyan where ever that colour occurred. Today during printing it displayed an error. Unfortunately I didn't catch the number. I...
Maybe an obvious answer, but have you cleaned the print heads several times? You can also remove the cartridges, remove the entire print head and clean it with rubbing alcohol and a q-tip.
Mar 28, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
107 people viewed this question
old marine
old marine
