Question about Pyramid Car Audio & Video
I bought the pyramid cr65 low pass active crossover. I hooked up the power and negative connections. Then I ran the rca's into the input and the rca's output to my sub amp. As soon as I turn it on it justs pumps in and out non stop regardless of the music. It wont play music. If I disconeect and bipass it my sub works fine??? When I hooked it up I spliced into the amp's constant,remote and ground. I cant figure out why its just pumping air??? could it be the rca cables? or I noticed on the wiring diagram the rca input is checkered lines and the out put rca diagram is solid lines? Am I supposed to use a "y" rca or is it supposed to have the sound go through like I hooked it up? Have you ever heard of after connecting a crossover the sub just pumping air like that?? Do I have to run its own constant, negative and ignition instead of splicing it? Or is is more likely to be a bad set of rca's? They were on the cheaper side.
    Top Expert:
  • Pyramid Master
  • 2,929 Answers
Recommend contacting a local car audio professional or Pyramid customer support directly here:
Posted on Feb 10, 2018
  • 3130 Answers
SOURCE: parallel connection of power mosfets with two of 5 smoking
The IRFZ46N are n channel high speed switches . They basicly drive the Mosfets. Sounds like you have some problem there my friend, and unless you paid alot for this amp. Its going to need probobly all the n channel switches as well as every mosfet + the bias resistors repalced. Before plugging in the amp jump out the fuse with a 100 watt light bulb.. If the bulb glows brightly when you apply power there is still a short in the unit and could be in the switching power supply section of the amp. If it glows bright and dims, The shorts are most likly gone. The bulb will minimize the amount of current the unit can draw and most of the time wont let the new parts blow out. Check out this service number and see if they can help you. Good Luck Main support number 978-823-0300
Posted on Jul 26, 2006
  • 116 Answers
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
Posted on Jan 28, 2009
  • 5 Answers
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Posted on Feb 01, 2009
  • 90 Answers
SOURCE: Pyramid PB449X In Protect Mode
The protect light is a notification that the amplifier has reached a set temperature and shuts the amp down till it cools off. Look for the thermosister on the heatsink and follow the circuitry back to the control chip. Once you get that fixed the amp should power up until it gets too hot and the protect circuit kicks in. I had one of these amps for a while and the circuit was very touchy. Regards, rcampsr
Posted on Feb 21, 2009
  • 655 Answers
SOURCE: there is no sound whatsoever
Hello worsttintent,
The FAI3A is a 4-channel converter. Perhaps you connected the input from your rear speakers to 2 channels but ran the RCA's from the other 2 channels. It's also possible that the levels need to be adjusted.
Check the wiring and adjustments. Put the RCA's in the unused channels and see if there's output from there. If this doesn't work, most likely, the LOC is defective.
Hope this helps.
Posted on Oct 17, 2009
Their are 2 power wires,2 negative wires and 2 rem is this getting ready to get this put i
Some amps come with extra, power,rem,ground, so you can , power up another Amp Without runing to many wires. , or using a power a parallel, being your 1st Amp your power block, and your remote, ground .
Apr 03, 2016 | Jensen JXA8BA2 Amplified Subwoofer, Max...
Tryin to hook up a mtx electronic crossover rt-01a. i dont know how to hook it up
Your basic crossover is going to have a power (+) and ground (-). Your power wire goes to the battery, and your ground goes to the frame. You will need to hook up your RCA or speaker wires to the input side. Then hook the other two RCA connections to your amp.
Apr 13, 2011 | MTX Car Audio & Video
Dose the pyramid 801 EQ have wire outputs or RCA outputs
This unit actually has high-power, speaker-level outputs, since it is an amplifier and EQ together.
Feb 03, 2011 | Pyramid 801 10-Band Car Equalizer
How do I hook up the two stereo output RCA wires ( 1 L & 1R ) to the EQ input wires that are green/green&white & grey/grey&white?
you will only be able to control 1 pair of speakers, you can try an inline converter. always buy a stereo with 3 preouts especially if you plan on using equalizers/amps ect
Sep 12, 2010 | Pyramid 801 10-Band Car Equalizer
How many watts is it
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
red -power
black/casing - negative(ground)
orange-is memory/ignition on
the rest are right'left outputs
Sep 19, 2008 | Pyramid 403G 7-Band Car Equalizer
A electronic subwoofer crossover
connect speaker wiring for car to speaker wire side. plug the rca's into the amp ground the ground wire. run a live from the battery to the power on the crossover and run the remote wire to the blue (iso connector) wire coming from the back of the radio
Jul 24, 2008 | Car Audio & Video
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
Installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
May 26, 2007 | Pyramid PR333E Home Equalizer
Car Audio & Video Logo
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
