How do I install with no disk ?
I have a modem router with no istallation disk - how do I install it ??? Its a BT Voyager 2091
    Problem Solver:
  • 19 Answers
Connect the router to your PC, then in windows go to the start menu, then click run, type in CMD which brings up a command prompt, type ipconfig/renew it will give you something like this
a bunch of info what you want is the default gateway 192.168.x.x
open up your internet browser and type in that number, it should bring you to your routers web interface so you can configure it. let me know if it works
Posted on Aug 06, 2008
Can't get ASUS RT-N13 WIFI router to work with my BT voyager ADSL modem
you need to enter the correct settings in the router. The username and password you were given originally by bt when you got the internet. You also need to choose PPOA (i think) if that doesn't work try PPOEinstead but i am sure its PPOA.
To enter the settings you should have a setup cd that came with the router run that and it will ask for the info i have stated
Feb 12, 2011 | ASUS Computers & Internet
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here -http://www.sohodata.co.uk/soho.htm But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –(http://www.btopenworld.com/broadband/adhoc_pages/driver_homepage.html#yahoodrivers) It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
Connection to intenet new router
hi
to login to the router your checkk the default gateway address and type the same in to the browser and launch in to the router to do check the configuration...
mac - check in network coonections
pc - ipconfig
cheers !!!
Feb 13, 2008 | Buffalo Technology AirStation WBR2-G54S...
How to connect brother MFC-5440CN to Bt voyager 2091
Connect machine to lan. Run the network drivers. PC should find the mfc.
In case you have to do some settings have a look into the network manual which is a pdf document on installcd.
When questions left go to brother homepage of your country and search your mfc and then the faq for networking answers.
Dec 30, 2007 | Brother MFC-5440CN All-In-One InkJet...
BT Voyager 2091 Wireless ADSL Router - DROP OUT
If you face frequent drop outs confirm with your isp that it's not a problem with line...and also check the physical setup of broadband check if your router is connected to main socket of your house where telephone line enters in your house......
now when you face drop outs check on your hard wired comp whether you remain connected or not if no its a problem with line..
if no reconfig your bt router for wireless network change the channel of your wireless network either to 1 or 11...
or either there is one other way reset your router to default settings by pressing the pin at the back of your router..
and after that your router will start its default wireless network i.e a unsecure network..
try connecting to that network if still the same there are drop outs it's a problem with router....contact bt to config the router...
Oct 01, 2007 | Computers & Internet
HELP PLEASE
You need to sign up to the ps3 wireless play just like xbox live but without paying. go to the sony website to find all the info.
Sep 13, 2007 | Sony Playstation 3 (PS3) Console
Eu is using Bt voyager 210..power/dsl off ..troubleshoot
if the cmr is using a BT voyger/// first try pwr cycle router/// wait for a min// if tht does not work... do ipconfig// if gettin the default/// reconfig the bt voyger// but i do belive the router maybe faulty//
Sep 12, 2007 | Computers & Internet
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
