Question about Dometic Rooftop RV Air Conditioner
Mod 59516:331 fan motor wount run, turns free, no fuses blown. A yellow wire from motor rubbed against compressor and has a small hole in it
  • lwh172 Apr 08, 2011
    wire is intact, is it possible the fan start comp. is damaged due to the yellow wire making contact with metal. The 20 amp fuse and breaker is OK.
    Is it possible the shorted yellow wire damaged the fan start comp. Fuse ok and breaker ok
    President:
  • 1,654 Answers
Are you capable of repairing this wire? If so splice it back together around the bad spot. Do you have a volt ohm meter to check for voltage at the motor? Can you chek for voltage at the selector switch also. Let me know if your getting 120vlt at the motor or is there power on the yellow wire that has a hole in it.
Posted on Apr 08, 2011
  • 1 more comment
  • Dcramer531
    Dcramer531 Apr 08, 2011
    These motors rarly go bad, some coaches have multible fuses on these so check again for a fuse in a different location. Mine has a breaker and a fuse for the ac.
  • Dcramer531
    It is possible but it didn't trip any breakers so I am not sure if that is the problem. I need to look at a wire diagram and find out what the yellow wire is that your talking about. Have you had a chance to see if there is volytage at the motor?
  • Dcramer531
    The yellow wire is for the energy management system if you have one installed. There is a not that states (If an Energy Management System-EMS (load shed) is to be used with the control system, two wires must be routed
    to the roof opening of the zone to be managed. The signal required for this function is a normally open relay contact.
    When the EMS calls for the compressor to shut off, the relay contacts should close. Connect the air conditioner yellow wire to the EMS wires (if applicable). Do not allow the yellow wires to short out or touch, because the compressor will fail to run.)
    So You need to make sure the yellow wire is fixed, covered in tape and not shorting out anywhere., you may need to replace it. I don't think it damaged the compressor but it may keep the unit from running. You could have also have a bad relay contact on the compressor if it shorted out. I would replace the yellow wires, and then check and see if the contacts are pulling in when you turn the unit on, if so then I would start worring about the motor or the compressor. Let me know what you find and what you can get done.
Blown fuse 7
I would trace the fault first. Could be a shorted chafed wire. Could be the motor, not very likely though, they usually go open circuit, unless you mean the compressor in which case it could be jammed.
Mar 03, 2017 | AC Cars & Trucks
Ac fuse keeps blowing
Look at the wires connected to the a/c compressor on your motor. You might have a wire that's shorting out, or rubbing against something.
May 17, 2014 | Chevrolet Cars & Trucks
Hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
see this causes and fix it. God bless you
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Oct 08, 2012 | Dometic Rooftop RV Air Conditioner
Why does my fuse for the radiator fan keep blowing
This is a sign that you have a power wire that is shorted to ground. First check the power wire leading to your fan to see if there is a possible short to ground. Sometimes if the wires are not secure, they can rub up against the spinning fan or melt against the exhaust, and then possibly short against the motor or frame. If the wires appear to be o.k., then check the fan motor to see if it is bad. Try spinning the fan blade manually and if it makes noise or won't spin, replace the motor. Once you isolate the short and repair it, you should be able to install a new fuse with no problem.
Sep 02, 2012 | 1997 Chevrolet Cavalier
The unit starts but the fan dont run
It made no sense to me that despite no visual issues, the fan motor is bad. So, with further research it turns out that the true culprit is the small thermistor/thermal fuse between the orange wire (ground) and motor winding wire. The thermistor is taped underneath the silver aluminium and yellow tape on the fan motor. I heard about this bad (open/no continuity) thermistor makes almost >99% of the fan motor problem regardless of any brand name because this cheap c-fram fan motor is NOT made in USA. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a thermistor or type of temperature sensor connected between the orange wire and a motor winding wire. On my motor this was no longer working.
The part marked "JET 123 NM1 2A 130C" is a thermal fuse. The 130C is the temperature rating. When the motor get hot (130C / 265F) the fuse opens. The circuit is broken and the motor stops.
The motor is still good. The fuse is blown. It must be replaced to get the motor running again. You could bypass the fuse but then you invite a fire hazard.
A replacement fuse is available from Digi-Key. It is a Cantherm SDJ1 DF128S (128C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1133-ND
Part cost 98 cents
You might want to go with the next higher temp (141C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1134-ND
Jan 03, 2010 | LG LHD45EL Dehumidifier
Have power and it runs. fan will not go on.
Part cost 98 cents
Dec 25, 2009 | Kenmore 54701 Dehumidifier
Cooling fan wount turn on
The temperature sensor instructs the computer to turn on the fan which tells a relay to turn on and it turns on the fan. The fan circuit also has a fuse that may be blown. The relay could be faulty. The coolant sensor may be faulty, but it also tells the computer to display the current engine temperature. If that seems to be working properly, then the sensor is probably ok. You say the fan sounds like it is running--have you looked at the fan motor while the sound occurs? The motor shaft may be turning inside the fan hub! If so, replace the fan blade--not the motor. Check with a wrecking yard for the part.
Aug 25, 2009 | 2002 Pontiac Sunfire
My aircondition on my 99 montana quit working.Replaced the blown fuse & it worked for less than a minute & fuse got blown again. Is the compressor bad?
The compressor runs off of the belt from the motor so its not likely to be the compressor but it may be the electric clutch on the compressor, or a short in the wiring, or the blower motor fan could be getting hung up. I'd buy a couple more fuses and run it for a minute a couple more times while listening for any abnormal sounds or check some of the wires you may find areas where the wires rub up against something or were accidentally damaged by any other work performed. Try running the heat and see if that trips the fuse, then run the fan on low speed, ect.
Jul 17, 2009 | 1999 Pontiac Montana
My air conditioner fan motor runs in reverse thus, none or very little air is coming out
The fan motor can be wired correctly for up flow and still run backwards for downward flow or reverse when you put the wrong value capacitor or connect a hard start capacitor to an already bad start dual cap. Case in point: I come across a condenser where the fan motor is running (in the right direction, up) but the compressor is not. I put a hard start cap on the dual cap. The compressor comes on but now the fan motor runs reverse. No other wiring was changed. The hard start cap connected to the defective compressor start cap shifted the current, voltage phase 180 degrees to make the fan motor run backwards. I removed the hard start cap, removed the defective dual cap and replaced the dual cap with a known good one and everything worked correctly.
Jul 09, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
118 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
