Question about Keurig Platinum B70 Coffee Maker
As soon as I put a kcup in it only fills 1/2 inch in the bottom of the cup. If it's just water it works perfectly. Descaling has been done numerous times. Does not say descale when this problem occurs.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 08, 2011
Keurig coffee maker note making coffee. How do
if you are not getting any coffee made at all then descaling wont help you. i remove the water container and you will see a little hole with a screen inside of it. i either take tweezers and fish around for any particles that are in there. i was absolutly shocked to find little fuzz pieces. this dust will block up the machine so it wont work. i have also {at work} unplugged unit and take off water resevoir and put sink water into hole for a bit, being carefull not to complety soak whole unit . then i dry it well and plug it back in. works like a charm for me. i have 2 keurigs and 1 that i manage at work. as far as descaling , once its back running you could put a half cup of vinegar and fill the rest with water and keep making fake cups of coffee till empty . then i refill with clean water and run a couple more times. this is really good for keeping the needle free from getting plugged. as soon as i have any problem with my machine not making full cups of coffee i will clean that bottom screen under water resevoir, and it always works for me. good luck.
Sep 09, 2014 | Coffee Makers & Espresso Machines
I Just love this machine however the past two days it is only giving me half a cup of coffee and then at the same time as it is filling my cup it is also putting the hot water back into the resevoir tank....
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 27, 2011 | Keurig B60 Coffee Maker
Water does not completely flow through
sounds like it is time to maybe do a descaling to the unit.
put about 1 cup of white vinegar in the water and let it do a cycle -- do it one more time and see if this clears it up,, then do 2 to 3 cycles of fresh water to clean out the vinegar. this should clean the unit to new working condition.
let me know if you are still having troubles -- as there are a few other things that might be causing the problem.
c...
Feb 15, 2011 | Keurig Ultra In Home Single Cup Brewer...
I have solved the problem with the leaking k cup adaptor. I purchased a 1/2 faucet (black semi hard rubber) washer, that can be purchased at any hardware or plumbing store. On the back of the washer it...
That will work for the adapter but will puncture regular kcups. I put a 1/4 inch spring behind the gasket(delta faucet part) I had to cut it down a bit. This will make it work for both the adapter and kcups.
Dec 29, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
Keurig B60. Brand New used maybe 4 Kcups. Now it won't fill a full cup setting. Maybe 1/4 cup. You reset, get a little more to run through. At this rate going to be a long time for a full cup. took...
if water does go thru it...try white vinagar/water mixture about 1/2 cup vinagar to full tank water..
run cycles until empty...NO Kcups..then run full tank of clean water.....
Dec 18, 2010 | Keurig B60 Coffee Maker
I just bought my Keurig B60 new from a neighbor who bought it and used it once. She didn't like it becuase it didn't fill up her cup. I've had a single cup Keurig for years, but it finally stopped...
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Oct 03, 2010 | Keurig Special Edition B60 Coffee Maker
My Keurig B70 will not dispense the coffee. I have cleaned it, cleaned the needle, etc. but it still won't work. If I turn it off and on two or three times it finally will pump...taking longer and...
did you clean both top and bottom needles? Did the paperclip insert at least 1".
Sep 26, 2010 | Keurig Platinum B70 Coffee Maker
B-60 Keurig. Does not give proper fill. The steam is weak.Stops in the middle of the filling cup process. Works fine if I just run water through it. Have descaled numerous times per Keurig instructions. I...
Feb 10, 2010 | Keurig B60 Coffee Maker
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
74 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
