Question about Blodgett (ZEPHAIREG-DOUB) Double Oven
Convection fan the fan quits occasionally on hi speed. it still will function on low speed.
    Champion:
  • 254 Answers
This is caused by a faulty wiring connector. It is a gray iec type connector there will be 8 wirs connected on each side of it. You can get a replacement from blodgett directly. Or what I have done is to eliminate the block using solderless **** connectors.
Posted on Aug 28, 2008
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
Upper oven problem,
The Keypad (membrane) switches seem to be malfunctioning, this is very common on ovens these days especially if the unit has been self cleaned often. If you replace the membrane switch the unit should have all its functions again.
Dec 23, 2007 | GE Profile JTP56 Electric Double Oven
How to use without the fan force?
You have to modes on your oven. One is normal and the other is convection or speed cook. The normal mode does not use the fan.
Post make, model number and serial number for more information. J
Jun 06, 2015 | Ovens
Imperial convection fan motor failed after a brownout. Is it the capacitor, motor itself, or is it something else?
OK door mech's first. The chain gear will not warp, it is probably a seized-up chain link and the turnbuckles usually wire-brush up fine. Add some release fluid and they should adjust easily. Check the grub screws in the chain gears as these DO work loose. The chains are fitted to the adjustment rods/turnbuckles with split links. The chains and links could be replaced if the old ones are just to seized to free off. Once the door is adjusted correctly, apply copper grease (Like the stuff used on brake parts) to the chains, gears, door switch cam and hinge points. Makes a massive difference to their reliability.
Now the motor. Several variants were fitted but if I am correct, all the ICV ovens had two 11-pin relays in the control panel one for high and one for low speed. If one fails in the on position, both high and low speeds are energised together (huge buzz no motor). The relays are far more likely to be failed than a motor (assuming a brown out was just a loss of power/low power and not a massive power surge/spike). Easy check for stuck relay is to take one out and check the motor on high then low speed. One would work the other would not. Now switch the relay that is unplugged and see if the opposite speed works. If neither speed works then check cook/cool/ off switch. The cool function and the door switch form part of a two-way circuit. If either the door switch or the cook cool switch are faulty you may loose the motor function. The switches have to be tested out of circuit so note the wire positions to aid correct placement when putting wires back. Only after you have done those tests should you go to the motor terminal box and test for voltage present. If it does prove to be a faulty motor, take it off and have it rewound or replace with new motor from Imperial. Certainly cheaper than a new oven!
Oct 27, 2012 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Frigidaire Gas Range with Convection--fan does not turn on
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
Dec 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Convection fan not working
Check for a bad fan motor or a jammed blade.
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
Blodgett (ZEPHAIREG-DOUB) Double Oven Logo
185 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
butch welch
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
