Question about Saeco Incanto Sirius Espresso Machine
The brew unit still won't fit back into the machine. I have clarified the make of the machine as I think you were describing a different machine in the last instructions. I do believe it could be a matter of reseting the brew unit.
  • 1,089 Answers
Hi
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must insert the drip tray and dredge drawer, close the door and turn on the machine without having the brew group in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray, and test.
Posted on Apr 08, 2011
Cannot place the brew unit back in place? Any sugestions?
Hi, On the back side of the brew unit is a spout that moves up on to the injecton pipe. The spout has a locking tab that is probably out of position from cleaning the brew unit. It doesn't move too much, but try to move it back into postion. Only needs to be out by a hair to stop the unit from correctly fitting back into place. Dazza REPAIRER
Sep 25, 2011 | Saeco V-spresso Espresso Machine
I'm unable to push the brew unit all the way in. This started when the brew unit was not properly inserted when the machine was turned on causing it to jam. I found the instructions that said remove a...
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won't go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Apr 14, 2011 | Gaggia Syncrony Logic 74884 Espresso...
Hi, My Gaggia Titanium shows a Brew unit missing error. I have tried everything i can think of; - cleaned the inside - removed and inserted brew unit multiple times - switched machine on/off (including...
Try taking the brew unit out, and clean the area inside the machine for coffee grains before reinserting it. There's a tiny sensor for if the unit is inserted, but it can be confused if the machine gets messy inside.
Aug 18, 2010 | Gaggia Titanium Espresso Machine
Brew Unit will not go back into place
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won’t go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Apr 18, 2010 | Spidem Trevi Digital Coffee Maker,...
I have a spidem villa coffee machine from Saeco. I cannot remove the Brew Group. It is stuck. The coffee grouds drawer will not go ikn all the way. It is blocked by a plate from the brew group (which...
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,( it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dreg drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dreg drawer, now replace the tray and insert the brew group. If it still won’t go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Jan 30, 2010 | Saeco Spidem Villa
Cannot get the brew unit back in after cleaning
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. If you have you key you can insert it in the front of the brew unit. There is a round hold in the center below the “Push”, and twist it clockwise until it stops and the 2 marks are lined up. If you don’t have your key you can do this. Push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Press the “Push” lever until you hear a click and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted, and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now insert the brew group, and replace the tray. If it still won’t go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Jan 05, 2010 | Saeco Caffe Charisma Espresso Machine
Machine is stuck in rinse cycle and brewunit
Take the brew unit out again, and try to twist the rotational mechanism so that the little arrows in the front of the axis align. This should allow you to insert the unit.
On insertion, you might also need to push the little handle on the front of the brew unit to allow the coffee trough to fit.
Oct 11, 2009 | Gaggia Titanium Espresso Machine
Machine states the brew unit is missing when it is fitted
try pushing something which swivel up and down on the right hand side of the brew unit. once done it seems to fit back in properly, it did for me
Jan 04, 2009 | Gaggia Titanium Espresso Machine
Water coupling pipe hits brewing unit
Try to put in dregsbox and driptray to your machine, then power it on so the machine can do the selftest.
May 02, 2008 | Solis Master 5000 Espresso Machine
Brew unit
Make sure you have brewing unit in start positions, if you have a press on your brewing unit make sure to press it to you hear a tick, then you can fit it in the machine.
Mar 02, 2008 | Saeco 762111651808 Espresso Machine
Saeco Incanto Sirius Espresso Machine Logo
275 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
