Question about Refrigerators
How do i drain the water from my water/ice disp on my sidebyside fridge for a six mounth shutdown
    Guru:
  • 683 Answers
Shut the water supply off and let it call for ice making and then it will empty, do the same for the water dispenser with a glass, then disconnect water line on bottom and let it drain.
Posted on Apr 08, 2011
No cold water, ice maker works fine but no water from the door
HI THIS SOUNDS LIKE WATER DISPENSER FROZEN.DEFROST FRIDGE FIRST.GOOD LUCK.ALI
Jun 27, 2012 | Samsung Refrigerators
My frige stays warm all the time it is a Hotpoint
evaporator coils are iced up on the freezer side. either take everything out of the fridge and unplug it and let it sit for a day to defrost, or remove the inside rear panel where there is frost and (with the fridge off) use warm water sprayed on the ice to defrost it (or use a hair dryer, but just until the ice is melted. do not overheat the metal). soak up the excess water (underneath the fridge, too), and turn it on empty. let it run empty for a day to get it cold, then put the stuff back in. if the stuff is in there when it's warm, the humidity will ice up the coils again.
Jul 23, 2009 | Hotpoint HSS25GFP Side by Side...
I have a maytag MSD2754GR, the freezer bottom is all iced
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
It took me about 20 minutes to do this.
Hope this helps.
Jun 22, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Hi i have a maytag sidebyside fridge/freezer the freezer is filling with water at the bottom and freezing and small amount of water coming out onto the floor occasionally
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Aug 08, 2008 | Maytag Refrigerators
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking inside refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds of dollars.
If you still have problems e-mail me at walkhill@cox.net
May 31, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore sidebyside
you are probably getting an ice build up on the evaporator and the drain also blocked with ice. take back cover off freezer and melt any ice off with careful use of a hairdryer. make sure the drain at the bottom of evaporator if free by pouring a little water down it. if blocked with ice, free with hot water and parience. if fault reoccurs, you have a fault on defrost system
Apr 17, 2007 | Kenmore 52673 Side by Side Refrigerator
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
