When i starts my laptop, i can see black screen. in bright light, i can read littlebit but now clearly. can you please tel me whats wrong? what i need to do?
    Sergeant:
    Champion:
  • 217 Answers
If I had your laptop model I could point you to the exact part. It is a bad LCD inverter. It is a small tube shaped circuit board located under the LCD screen behind the screen bezel. One end connects to the LCD data cable, and the other end has a 2 pin connector that goes to the LCD backlight bulb. The part is usually about $10-15 and is relatively easy to replace yourself. Remove the screws on the bottom of the screen bezel and carefully pull the bezel out toward you. You will see the inverter there. Unplug both ends, replace with the new one and re-assemble. when i  starts - cheifhoho.jpg
Posted on Apr 08, 2011
  • 42 Answers
Sounds like the backlight inverter is shot. The inverter is a high-voltage power supply that runs the fluorescent backlight bulb(s) behind the screen. If you can see the screen in bright light or with a flashlight the core laptop is okay. Also you can connect an external monitor and use it this way.
  • 10,319 Answers
Start it up and keep hitting the f8 key till a service screen appears if possible
Laptop is on but screen is black
Try an external screen. That will exclude the motherboard. Shine a bright light at the screen, if you can see a picture, the back light has failed.
Dec 30, 2013 | Toshiba satellite c660
Toshiba Equium A300D - 13X laptop black screen.
Hi. try accessing the Start-up BIOS features by pressing F2 or Delete key when you see the Toshiba logo. Check for the Tab that will give you the control for the brightness/contrast of the screen. If that doesn't do anything then most probably the backlight (LED or CFL) must have been busted. and needs replacement.
^_^
May 06, 2010 | Computers & Internet
My hitachi 15.4 inch laptop monitor is not working, i can read and see everything but its very dark so what is the problem and how can i read it clearly?
Hi:
You should first try to increase the screen brightness by holding down your function key and hitting the screen brightness key. If you have tried that, borrow a computer monitor, and connect it up to the VGA output connector on your laptop. If you toggle to an external monitor, by holding the function key, then the monitor key, you should be able to tell if the video is bright on the external monitor. If it is ok, then your laptop has either a bad LCD inverter, or backlight bulb.
Nov 19, 2009 | Hitachi CML154XW (Beige) 15" LCD Monitor
Dell screen goes black , after 2 seconds but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time ,
but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time......WHAT?
Can you explain in a bit more detail please...I don't know what you mean by.........
'when low down the brightness it work good'?
But try holding down the FN key on your keyboard & tapping the 5fc1ca0.png Button that alters the brightness.
Sep 04, 2009 | Dell InspironTM 1501 Notebook
Low brightness
that would probably be a failure with the lcd inverter other symptoms would include redness of the screen and sudden black-outs.
Jun 24, 2009 | Sony VAIO VGN-CR205E/P Notebook
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
Brightness
open the monitor you will look big black part called EHT you will see the movable shaft on it rotate it by screw driver in active supply monitor see on screen suficient brightness and stop you will be satisfied
Nov 21, 2008 | Hansol 500 A Monitor
Loss of light on screen Dell Inspiron E1705
Hmm, this could be a problem with the backlight inverter or something as simple as power settings.
In power settings from control panel there should be an option to alter the brightness lever of the screen when on battery.
Have a look in there and set it to default to see if it makes any difference.
Let me know if you need any more help.
Regards
Nick
Oct 26, 2008 | Dell Inspiron E1705 Notebook
Unable to print message on the LCD
press MENU then the blue copy button (b/w) then fourtimes the arrow up button quite quickly after another.
Machine should switch to maintenance mode and all lights will flash.
Mar 11, 2008 | Brother MFC-5840CN All-In-One InkJet...
Mac laptop displays minimum brightness
Check to see if there is a box right below that... Saying something along the lines of readjust to brightness of surroundings, etc!  Make sure box is unchecked for you, in regrds to your issue and then see if that helps!  I will look a little further into it for you!  Let me know if that helps though!
Feb 23, 2008 | Apple MacBook Pro Notebook
Computers & Internet Logo
David Payne
David Payne
