Outside unit humms fan isn't turning and heat is coming off unit..
  • 1 more comment
  • dagwokamoli Apr 08, 2011
    the blade turns not loosely but it turns...
    fan body isnt hot when unit is off.
    my outside unit is hummin and fan doesn't turn when uit is on.. heat comes off unit when on and hummin.. da fan turns manually when unit is off but its tight hard to turn.. is it fan motor , compressor or????
  • 1,606 Answers
The fan may be stuck because of foreign material or the fan motor bearings are stuck. There would be two sources of the heat - the fan motor is hot because it is overloaded, and the compressor and condenser are overheating because the fan isn't running. I suspect the hum may be from the stuck fan motor, but it may be compressor sound you normally do not hear over the fan noise.
It is possible the fan motor is not getting power. A quick check for this is to remove power from the air conditioner, then cautiously feel the fan motor housing (you would have to remove the fan guard to do this). If it is cold, there is no power on the fan, but if it is hot, the motor is getting power but is unable to turn. You do not want to do this with power on - if you should somehow un-stick the fan with your hand in there, you could be seriously hurt.
Posted on Apr 08, 2011
    Guru:
  • 683 Answers
You need to turn off unit. The condensor fan motor is not allowing the heat to excape. If you dont have any type of head pressure control you will burn up the compressor, Check the fan body and see if its hot and see if you can turn the blade. if its hot let it cool down overnight and try to start it in the morning. Sounds like you have a bad condensor fan motor, let me know if i can be of any more help.
relaga58
  • 158 Answers
SOURCE: Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
Posted on May 28, 2009
  • 10 Answers
SOURCE: did the bryant inhome test. everything works but the outside unit it clicks and humms . the fan won`t turn
check for bound motor
Posted on May 31, 2009
jumptrout51
  • 3361 Answers
SOURCE: outside unit fan wont turn on with inside unit and
Replace the dual capacitor on the outside unit.
Posted on Jun 08, 2009
  • 6 Answers
SOURCE: outside unit will not come on
could be the slow blow fuses in the disconnect box. check them for conntinuity if you don`t get continuity replace the fuses. check for power @ the contactor. the contactor is where the wires from the diconnect box attach to the ac. check both sides make sure your getting 240v be careful not to touch the wires ofcourse. if your getting power change the capacitor. may need a hard start for the compressor as well.
Posted on Sep 02, 2009
cool78259
  • 228 Answers
SOURCE: Fan outside isn't running and
The fan outside keeps your compressor cool, the compressor, if left running without the fan running to cool it down can get damaged, the fan normally gets its power from a switch box located outside or near
it. or the motor on the fan could have just gone bad. the fan motor is not as expensive as the compressor to replace. its easy to replace. sometimes what goes out 1st on these motors is the capacitor,the capacitor stores enough voltage to give the motor that extra push to turn. many times its just the capacitor that goes out. when you purchase a motor make sure you also get the matching capacitor.if you can turn the fan and it starts running, its the capacitor, if it starts running and has any kind of bearing noise then you will have to replace the motor. good luck!
Posted on Aug 08, 2011
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
Sep 08, 2014 | Heating & Cooling
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
We have a 6 year old air conditioner Byrant 591B. The outside unit is not working it make a slight hum when the thermostat is set to cool, but the fan does not run. The furnace is working fine
You picked the wrong picture...lol. You have a split system and that humm you hear comes from the contactor. That means the thermostat is asking the compressor which is outside to come on. If you hear the humm but nothing is working, Check the breaker and then replace the fuses in your fuse box by the condensing unit, or the outside unit if the breakers are OK. It should have a disconnect between 3 to 10 feet of the unit depending on your codes and city requirements. No matter what, if you stand at your unit and look at the conduit, it will lead to your electrical disconnect. It could be a sub-breaker or fuses. It is usually fuses because a breaker could take up to 6 sin waves to respond as where a fuse could take only 2 sin waves. Replace both fuses. As time goes on, fuses become warn from constant load changes and heat and sooner a latter, they just wear out like any other component. Change the fuses and fire your unit back up. If it pops the new breakers, you have other issues and it's time to call an HVAC guys.
Sep 28, 2010 | Bryant 462AJC021BA Air Conditioner
Is it normal for fan on outside unit to be on while on heat mode
Yes, it is normal with a heatpump, you run the outside unit in cooling and heating.
It is also normal when the outside unit goes into defrost for the outdoor fan to shut off during the defrost mode and to see steam coming out of the outside unit, while it's melting the frost or ice, then the fan will come back on.
Jan 06, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My heat willnot come on all i here is humm in the unit under the house and nothing inthe outside unit it is a "Googman-ARUF02400A1"
Ok, If you don't have a heat pump, you should not be hearing anything from the outside unit. I assume you have electric heat. I feel strongly that you have a bad fan motor capacitor. This is what sends a jolt of power to start the fan motor. Good luck and have a great day.
Oct 18, 2009 | Goodman Heating & Cooling
May 28, 2009 | Heating & Cooling
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
