Question about Dell Inspiron 1545 Notebook
Ac power supply/converter does not charge battery or run computer. Converter is working correctly. Attempts to start are met with 4-flash repeating sequence and off.
  • Daniel Wakefield
    Daniel Wakefield Apr 08, 2011
    How do you know the converter is working correctly? Have you been able to test it with another system?
  • Dale Apr 08, 2011
    I did the reverse, I tried a known good AC converter on this unit and it still would not powerup or charge the battery.
    Scholar:
  • 142 Answers
Try taking the battery out and working with just the power cord. If it still does not work, even with a known good power cord, then either the power jack on the laptop is bad, the motherboard is bad, or the memory could be bad.
Posted on Apr 08, 2011
Testimonial: "Well, that's what I expected. Two out of three options make it an expensive paperweight. thanks"
  • Daniel Wakefield
    Daniel Wakefield Apr 12, 2011
    Just because the motherboard is bad or power jack is bad does not mean the computer cannot be used again. It is possible to replace the motherboard on those machines. I have done several myself. Just need to find the right motherboard. usually cheaper than buying a whole new computer.
Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Apr 05, 2012 | Lenovo IdeaPad U550 (374955U) PC Notebook
Hi, sounds like you understand power converters. I have a 96 Hitchhiker fifth wheel with a 40 amp magnatex converter with bat. chager. The problem I have is that is does not charge the battery with the...
It sounds like you may have some wiring issues. The inverter simply changes DC battery voltage to 120 volts AC. This will allow you to have AC voltage without running a generator.(noise issue).You probably need to find a well recommended RV repair shop and have a tech look things over.
Jun 20, 2009 | Electronics - Others
Powering car stereo using AC to DC power converter
your power supply may not have enough power to run the radio.
Mar 31, 2009 | Car Audio & Video
I have a HP NC 6120 laptop.I have the batt in and the PS plugged in.All that happens is the Charge Light Blinks yellow 6 times then green 1 time,repeats.At the sametime the power light comes on for 6...
Remove the battery and then press the power button for 45 sec then refix the battery and check that the machine is turning on or not?
If the laptop is not working on AC alone then this is the issue with the converter which is there on the motherboard.
Feb 19, 2009 | Toshiba (K000006610) for Satellite P25...
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
Dell Inspiron 1545 Notebook Logo
154 people viewed this question
Alun Cox
