Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Does the husq 440e have an oil adjustment on it?
  • 710 Answers
Hi mwaltz48,
Yes, Huskys have a screw adjustment on the bottom, under the chain sprocket assembly.
While looking at the bar side of the saw, turn it over and you'll see a screw that has 3 positions.
Turn the screw to the right will decrease the oil flow, left to increase it. If you put a longer blade on, you should increase the oil flow.
A way to check your oil flow is to run the saw with the blade pointing at something light, such as a freshly cut chunk of wood, or the end of a log, etc. You should see a light line of oil appear.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 08, 2011
2 Suggested Answers
slohry
  • 87 Answers
SOURCE: HOW DO YOU ADJUST THE OIL PUMP ON A HUSQ. 359?
There is an adjusting screw on the bottom of the saw underneath the chain/clutch side of the unit.
Posted on Apr 09, 2009
How much oil and what type of oil should I use in the trimmer?
You use no oil,use regular unleaded gas only,on 4-Cycle engine use gas,2-Cycle engines use the oil- gas mixture,your's is better cause you just need gas.I use Husq's too.
Apr 13, 2016 | Husqvarna 224L 25cc 4-Cycle Straight Shaft...
I have a husq/136 chain saw 2002 replaced oil ppump and pich up tube it still pumps to much oil on chain
this can happen when the two plates are missing that go on each side of the blade, or there is a oil adjust screw that controls output of oil, but lots of oil is a good thing as long as it last a tank of gas, if not it can be a bad thing !
Nov 07, 2013 | Husqvarna Garden
Husqvarna chansaw 440e spitting to much bar oil
The 440 has a fixed non adjustable oil pump, it can only deliver a set amount of oil, it is regulated by engine revs, so if you are only cutting small branches it will have high revs and will deliver more oil.
Mar 28, 2012 | Garden
Husqvarna 340 will not idle
To set the H and L adjustments, screw them in until they lightly seat. Then back both out 1 1/2 turns. This will get you in the ballpark. They will still need to be fine tuned for proper settings.
Apr 03, 2017 | Husqvarna Garden
What 2 stroke fuel ratio do i use for the es 2400 leaf blower
50 to 1 don't use outboard 2 stroke oil. Use good oil echo, still, Husq ect.
Sep 27, 2010 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Where can I purchase a wrench to adjust the carburator on a 440e chain saw?
Purchase at any hardware or home improvement store (ACE, True Value, Lowe's Home Depot etc)
Jul 06, 2009 | Husqvarna Garden
My chain is not getting oiled when I use the saw.
Sounds like the oiler is clooged where the oil comes out on the chain. Probablly has sawdust in it. Remove the chain guidebar and clean the oiler.
Apr 28, 2009 | Garden
Mar 25, 2009 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
411 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
