Question about Whirlpool Washing Machines
Whirlpool extra large capacity top loader washing machine motor is running, but will not wash or spin
  • taffurs Aug 07, 2008
    I dont know yet but we will try your solution
    thank you
    Genius:
  • 3,422 Answers
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Aug 06, 2008
  • 5,911 Answers
Sounds like you may have a bad motor coupling. This is a common fail item as the either the rubber bushing, or the pins on the coupler shear off or strip. The following link provides you with instructions on how to replace:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
This is actually a very simple repair at an inexpensive price 9if you do it yourself). If its not your motor coupling, please post back and let me know. I hope this helps you.
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
Whirlpool super capacity plus (commercial quality top loader) does not spin on all settings and does not spin fast enough
sounds like you have a worn out clutch. depending on model it could be an easy fix. would need to know model number to know for sure.
Apr 03, 2013 | Whirlpool Washing Machines
Whirlpool top loader model LSQ9010pw6 won't spin but does drain.
Sounds like you need to replace the Clutch Assembly- Complete clutch assembly for direct drive washing machines. Comes with brake cam driver. Includes blue spring for large capacity washers and black for compact washers.
this video should help
http://www.youtube.com/watch?v=tVc6SZ2DD4U
Aug 13, 2011 | Washing Machines
Whirlpool washing machine LA5310XPWO wont agitate -- what would cause this and how can it be repaired?
Is this a top or front loader? If it is a top loader do you hear the motor run? If you do the first thing to check is the rubber driver between the motor and the transmission. One way to chek if the motor runs is to fill it with water and put it into spin. If it pumps the water out that means the motor runs. If the rubber driver is broke (happens often) it will neither wash nor spin.
May 20, 2011 | Whirlpool Washing Machines
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
I want whirlphool whasing machine with dryer please give the gideline of it and its price my e - mail ID is sabiha_1993@hotmail.com.
Washers are more advanced and stylish than ever before. When you're buying a washer, look for features that make washing easier and more efficient, less costly, and kinder to fabrics. Thanks to advances in technology, it's all possible - and our washer buying guide shows you how.
Washer Types
Feature options, capacity, energy use and style are all factors to consider when deciding between a front- or top-loading washer.
oth top-loading and front-loading washing machines will do a good job of cleaning your clothes. The most significant differences between these types of washers are capacity, energy efficiency, water use, feature options, and style.
Top-loading machines
Traditional top-loading washing machines are available in a wide assortment of models, price ranges and styles. The most basic top-loading washers perform very well and are generally a good value for a no-frills, clean wash. Other top-loaders offer more cycle and temperature selections, spin speeds, and fabric care extras as they increase in price. Overall, top-loading washers are generally less expensive to purchase than front-loading machines, but are slightly more costly to run because they use more water and electricity.
Most top-loaders fill the tub with enough water to cover the clothing, then agitate them to get the clothing clean. Some manufacturers now offer high-efficiency top-loading washers using a number of different technologies. One such technology is the Whirlpool® Calypso® wash plate. Instead of agitating fabrics to get them clean, the wash plate moves them through a shower of concentrated detergent and water. The action is gentler on fabrics; it's designed to provide better cleaning with far less stress to garment fibers. And with the agitator out of the way, the washer has more room to clean bulky items such as comforters and rugs.
Standard capacity for a top-loading washing machine is 12 to 16 pounds per load. The Calypso wash plate model can hold up to 18 pounds of laundry (think the equivalent of 16 pairs of jeans).
Here is a link to some Whirlpool washers for you to look over.
Dec 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
7.5kg top loader Whirlpool - 5yrs old. Overloaded
Looks like your motor/gearbox combination is broken. not worth the repair. By the time the top drum is removed, it will cost for motor/gearbox:top drum(will break when trying to remove) and labour. Cost will almost be the same. For the same price i would opt for new because at least you get a proper gaurentee.
Sep 21, 2009 | Washing Machines
Washing Machines Logo
134 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
