Question about Home
Water constantly runs in toilet. occasionally will semi-flush on it's own. How do I adjust mechanisms to prevent this?
  • 413 Answers
Change the rubber flapper in the bottom of the tank. This is the way water stays or leaves the tank. You can find the flapper by taking the top off the tank. Flush the stool and you will see the flapper come up . it is at the center bottom of the tank. turn the water off to replace it, and flush the tank after you have turned the water off to get as much water out of the tank as possible to replace the flapper. you can get a new flapper at any hardware store for just a few dollars
Posted on Apr 08, 2011
Both the flush buttons have jammed in the flush position.
To open the assembly, first line up the flush buttons with the float mechanism. This aligns tabs on the button mechanism with a slot on the mating surface allowing you to 'pop' the button assembly off with the help of a screwdriver. It will also prevent breaking off the tabs. If you break off the tabs, the button assembly will not lock in place when you reassemble it (speaking from experience).
2. Carefully pop off the button assembly with the help of a screwdriver.
3. Disengage the lever from the valve assembly by carefully prying with a screwdriver (see video).
4. Pop off the lever from the axle on button assembly and remove.
5. With some fine grit sand paper or emery cloth, polish the casting marks off of the axle.
6. Reassemble the mechanism. Assembly is the reverse of disassembly.
http://www.instructables.com/id/How-to-fix-leaking-Water-Ridge-dual-flush-toilet-f/
Dec 21, 2015 | Kohler Home
How difficult is it to replace toilet tank equipment?
The job is easy if you have any plumbing skills. Turn off the water. Disconnect the water hose at the bottom of the tank. Remove the nut holding the flush/fill mechanism and remove the mechanism. Reverse removal procedures and complete. Adjust for proper water level in tank.
Dec 03, 2014 | Home
Wand will not launch when seat is activated
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism . Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Home
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
Nov 25, 2013 | Delta Home
Adjust water level in in-wall Italian toilet cistern
It could be your flushing mechanism inside the tank that is letting the water in even after the flush. First flush and watch the bottom mechanism whether it blocks completely when water is full in the tank at set level and no more water flows.
Jul 27, 2013 | Home
I have a Duravit Starck 2 toilet cistern which is approximately 5 yrs old, recently water from the cistern runs constantly into the bowl. I have renewed the flush value without any success. I would...
Did you replace the flush valve or the flapper?
There must either be a problem with the seal between the two surfaces of the flapper and flush valve or the flapper is being prevented by the flush system to returning to make a seal against the flush valve after the water completes draining during the flush cycle or more likely water is draining through the overflow tube.
Make sure the sealing surfaces are clean and not damaged.
Make sure the flapper is not being interfered with and is able to return to the closed position to make a complete seal against the flush valve.
Check adjustment of the water fill level to make sure the water is not filling above the water overflow. If the inlet valve does not shut-off when the level is adjusted to the proper level the water inlet valve may need replacing.
The following videos may prove helpful.
Dec 22, 2010 | Home
Our Toto ultramax model MS853113S will constantly
flapper most likely needs to be replaced not sealing completely is one problem----- the other is float level not shutting off water valve --and other is bad water valve not shutting off or worn and needs to be replaced remove cover and turn water on watch water level lift float up if water turns off valve good----turn off water if drain down flapper bad and needs replacement costs a couple of dollars to replace -if water stays level in tank than float needs adjustment or replacement
Aug 01, 2010 | Toto MS853113S#01 UltraMax Round Toilet,...
Constantantly dripping after tank is full
WHAT IS DRIPPING,?THE TANK ?OR IS STILL FILLING UP ?IT SOUNDS LIKE YOU NEED TO ADJUST THE WATER LEVEL TO THE PROPER 1.6 GALLONS PER FLUSH,WHICH IS MARKED ON THE INSIDE OF YOUR TANK SOMEWHERE,CAUSE WHAT YOUR HEARING IS THE WATER RUNNING DOWN THE OVERFLOW TUBE
Apr 09, 2010 | Toto Aquia II Dual Flush Toilet
The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
Feb 19, 2010 | Kohler - Toilet - Two-piece - Highline -...
Home Logo
98 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
