Question about Makita Garden
Makita uc35020A no lubrication reaching chain
  • 3,740 Answers
I have tried multiple versions of the model number you provided in hopes of finding any form of reference material that I could use to help you without success. The closest match I can come up with is for a Homelite Snow Thrower UT-35020 A Can you please re-check your model number and respond so I can better help you?
I am going to use UC3520A to answer this question.
Using this link / expanded picture:
http://www.powertoolspares.com/tool/makita/spares-and-accessories-for-uc3520a/uc3520a/spares/#
(you might have to copy and past the link due to the # sign at the end of the link )
This Electric chain saw has a tiny oil pump and 2 sections of hose that route oil to the bar. You have to take thing saw completely apart and verify that all the connections are good and that the oil pump is good. You need to inspect items 36, 37 and 38. (pump tube and spring) Note that the tiny o-ring is not listed.
Any one of the above items can cause your symptom.
Thanks,
Kelly
Posted on Apr 08, 2011
Automatic oiler problem since date of purchase. Remedy?
No found recall for this. link below not your exact model, may help on repair of oiler
Chainsaw chain oiler repair
Jan 16, 2016 | Makita UC3530A 14" Electric Chain Saw
How do i adjust the chain oil flow rate
to test if your oiler is functional remove bar and chain and start unit. if it drips oil with bar and chain off then clean the oil hole in the bar. if plugged it will prevent oil from reaching bar for lubrication of chain
Sep 16, 2014 | Garden
Oil no longer lubricates the chain on saw groove and oil hole are clear
Sometimes saw dust and shavings block the oil port and track strip down the bar and chain there maybe a cover over the oil port remove this and clean carefully replace all remember to clean the bar put the chain on do not over tighten run the saw if there is no oil you may have damage to the oil pump this can happen if the saw was used with no oil or a blocked oil way some of the pumps will overheat causing damage hope this helps good luck
Jul 24, 2014 | Makita UC4030A 16" Electric Chain Saw
Makita dcs 330
The chain oiler may have gotten clogged with debris
Sep 29, 2013 | Makita Garden
Chain keeps coming off my new 16" Makita chainsaw. Any suggestions?
Make sure that your chain is properly tightened and that the bar does not have any dents or dings in guide groove.I like to have my chains tightened to where you can pull them up at the mid-point of the bar about enough to fit the thickness of a nickle in between it and the bar.Do this when saw and chain are at operating temperature.If nothing else helps try a new chain if you have reached the end of tensioning adjustments. Thank you.
Mar 25, 2011 | Makita 33cc Chain Saw w/16" Bar DCS34-16A
Chain maintenance
Whether or not your chain needs adjusting, you'll want to keep it clean and well-lubricated. Most modern chains are o-ring types which use rubber components, and are sensitive to certain solvents. Make sure you use an o-ring approved cleaning agent when you spray the chain and sprockets or use a soft brush to apply the cleaner. Next, you'll want to wipe off the excess grime using a rag or towel, which will create a clean surface that's friendlier to lubricants. Be sure to thoroughly reach all the sprocket teeth and chain links by rolling the rear wheel (or the entire bike, if it's not on a stand.)
Nov 20, 2008 | 2006 Harley Davidson FXDI Dyna Super Glide
Chain maintenance
Nov 20, 2008 | 2004 Harley Davidson FLHRS - FLHRSI Road...
Chain maintenance
Nov 20, 2008 | 2005 Harley Davidson FLHR - FLHRI Road...
Garden Logo
52 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
