Question about Samsung SGH-D900 Cellular Phone
How 2 unlock sim card - Samsung SGH-D900 Cellular Phone
How to unblock my sim with puk
Unlock SIM card with PUK code
SIM cards lock after three incorrect PIN entries in a row. Your device may display "Enter PUK" if the SIM card locks. To unlock your device's SIM card, you'll need its PIN Unlock Key (PUK) code.
To get the PUK code to unlock your SIM card:
  1. Select the myAT&T tab.
  2. At the top of the page under Wireless, select My Phone / Device.
  3. If needed, click Select and choose the mobile number of the device that needs the PUK code.
  4. Under Support, select the Unlock SIM card using PIN Unlock link.
  5. Use the PUK code and instructions provided on the Unlock SIM Card Using PIN Unlock Key screen to unlock your SIM card.
May 08, 2015 | Cell Phones
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Sim
Did you mean your Samsung S8000 Jet phone displaying invalid Sim card?You need to unlock it from current network lock,to use other network sim card.Visit the site Mobileunlocksolutions.com get unlock code and unlock it easily.Then use with any GSM network sim card.Check whether unlock code is available for your network and country.If it is available get it and unlock it.You can unlock only GSM network locked phone.You cannot unlock CDMA network locked phone.After unlock your phone you can use any GSM network sim card in it.You cannot use any CDMA network sim card in it.
Jun 17, 2013 | Samsung Jet S8000 Cell Phone
When i insert my sim the phone does not support the sim
You will most likely have to purchase a new sim card as some phones are sim card specific. Also try a jail breaking program or have it done.
Sep 26, 2011 | Samsung Cell Phones
It will not read my tmobile sim card
It's not reading Only T-Mobile Sim card ?It's not reading other sim card also Expect Only One Sim card?
If it reads only Sim card and not reading Other Sim card like for Example T-Mobile,AT&T,Orange etc means it locked to Network ,you have to Unlock it To use any GSM Network Sim card,What is Mobile Phone Brand and Model?Find the Network ,Country it locked now? then first please You can find it locked To GSM Network or CDMA? Network CDMA Network means You cannot Unlock t to use any gsm Network Sim,Gsm Network Lock means You can Unlock it to use other Network Sim card...You can Unlock it using the Unlock code,You can get the Unlock code and instructions at here
Unlocking4u.com and Unlock it from Network Lock,then you can use with T-Mobile Network surely.
Aug 13, 2011 | Cell Phones
How do i unlock a sim card with a puk code?
contact the service Provider........
Oct 29, 2010 | LG KU990 Viewty
Samsung SGH-D900 Cellular Phone Logo
27 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
