Question about BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
Not really a problem. Just looking for a manual so I understand how all of the adjustment functions work.
    Problem Solver:
  • 5 Answers
Have you tried contacting BSA directly? I searched for an on-line manual which you may have also.
I didn't have any luck, but I do know they provide on-line manuals for many of thier products.
E-mail them from the link provided below and you should get what you need.
Here is the direct link to thier customer service contact info.
https://www.bsaoptics.com/Contactus.aspxe.
hope this helps you!
Posted on Apr 08, 2011
I don't understand the timer on a Kenmore Dehumidifier
I do believe this one of those models that uses one display for both setting of humidity level and the timer , make sure you are viewing the timer function and not the humidity function , this is a very common complaint with these type as many times one sets the on time correct but then sets what they believe to be off time when they really are adjusting the humidity room level , there should be tiny lights that show function you are adjusting
Feb 18, 2014 | Kenmore 30-pint Dehumidifier with...
How to adjust the Rated Motor Current in keb combivert f4-c. I cannot understand in manual
Run the motor with no load to see if it functions with no load.
If the system functions with no load, you may still need to increase your acceleration time to reduce the current demand.
What is the part# / serial# of the inverter in question?
Dec 28, 2013 | Inverter KEB COMBIVERT F5
Want to learn how to do a front manual wheel aligment on my 1986 chevy pick up truck
You are asking way to much for my typing skills. I really mean get a book that explains the "geometry" of a car or truck front suspension. There are so many different things that come into "play" you really need to read a alignment book to understand what I am trying to say. Try looking up Camber or caster adjustment, this may get you pointed in the right direction. Dan...........
Apr 29, 2011 | Chevrolet C2500 Cars & Trucks
The brightness of my laptop is very high
There should be a function key (usually labeled "FN") on the keyboard. There will probably also be buttons with brightness adjustment labels on them. Usually the arrow up/down keys adjust your brightness while the FN key is pressed. The adjustment keys are usually labeled with a picture of the sun with an up or down arrow beside it - almost always in a different color than the letters on your keys [maybe light blue?]. Otherwise you may have to adjust it via software in the control panel. Good luck.
Apr 05, 2011 | Computers & Internet
How to increase the brightness on my Toshiba serial #472011022k?
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function keyjhay_torida_0.jpg (abbreviated as "Fn") and pressing the up or down arrow key as shown in the picture below, increases and decreases the brightness.
Mar 02, 2011 | Computers & Internet
The problem is that i simply dont have the users manual and dont understand how to manipulate my watch
mcdevioto75 here, I'll try to help, 1 of the buttons should say mode, if no button look for a in-dent naer the other buttons and push that in, or press the mode button and see the dial blinking, press set to cahnge and adjust each function, Hour, Minute etc. after each function is set press mode to mave to the next function when done with your functions, press mode to return to a staedy dial.
Jun 21, 2010 | Watches
The garage door opener i have had fitte will not accept its codes ,eg pushing black button to desired height and then pushing remote to set the desird height .(then its supposed to do its own trial run...
I,ve worked for sears installing theese machines for ten years ,my brother called me up to do the adjustments on it and even i had a hard time ,the best solution i can give you is have a qualified sears technician come out to your house to do the adjustment otherwise if you do something wrong you can damage your door ,this is not something i can explain in an email because it is tricky , i have to agree though that this is not a user friendly adjustment ,in the world of automation their are just some things that are better left alone! if you have a steel insulated or non insulated door even more the reason not to atempt this adjustment , your door can buckle under the pressure of the machine and it will cost you dearly for a new door , if your door is wood and is in good shape then if you feel you really want to try adjusting it yourself then refer to the owners manual and read it and understand fully before you program the up and down adjustment also at this point you will want to set the pressure sensitivity to it,s lowest setting so your door does,nt have alot of down force pressure while making the height adjustments , i hope i was able to give you some insight in this and im sorry i was,nt able to give you the answer you were looking for but this is just one of those questions that really can,t be answered through an email , i hope you understand and good luck with your adjustment , sincerely glenn mayer
Aug 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
FUNCTION KEY:(
try, right click on my computer icon>properties>hardware tab>device manager>, then look down the list to your keyboard, click + sign, right click on keyboard select uninstal and then reboot notebook and keyboard will self install. If still not working your drivers may be corrupt and will need to be downloaded from the Asus support website.
Oct 05, 2007 | Computers & Internet
Power zoom function
If you have the difuser on the zoom does not work as it assumes you are at close range. Remove the defuser and try again, good luck , Bob.
Jan 05, 2007 | Nikon Speedlight SB-800 TTL Flash
BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope Logo
440 people viewed this question
Top BSA Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a BSA Optic Expert? Answer questions, earn points and help others
