Question about HP (226519-001) (226519001) 3000-Watt Power Supply
Hi guys, i have a power supply HP-Compaq-226519-001 bought from ebay. the seller said it is a working pull-out and i was able to locate the AC input terminals/pins as well as the DC output terminals but it wont power up. is there any control pins to be manipulated so it will power-up like shorting the green and black in the case of pc PSU? thank you very much. seth
  • HP Master
  • 27,725 Answers
Most power supply units will fit you can get a larger wattage output eg: heavy duty if you have added any more devices to your computer more RAM,a larger hard drive,more cd/dvd drives these added will put a greater need for wattage output on the PSU
you should check all the electrical connections before you make a decision and make sure they are the same as as the ones that you will need to run your computer also
check the measurements inside the frame to make absolutely sure it will fit
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 08, 2011
    Sergeant:
    Champion:
  • 217 Answers
Go to this link. Click HERE. Unplug from the motherboard FIRST. (all other leads too) You can test by using a paper clip to short pin 14 (green) to 13,15,16, or 17. This will power on a working power supply.
Can a hp pavilion dv5-1127cl power port work in a
Hi there
I think in this particular case it might not be wise. The power blocks for these two appear to be different wattages (65 & 90 respectively) and also the connector to the laptop does not look to be the same, in which case damage to the power inlet socket of one or the other laptop could occur if you tried to fit it too energetically. I did find this eBay seller who gave quite a list of compatible laptop models for the power supply he was selling, but although the DV7 series is there, the DV8 series isn't.
AC Adapter Charger for HP Pavilion DV5 1127CL DV5 1128CA Power Supply
I think you would be better to get a power supply that exactly matches to prevent potential future problems.
Perhaps not the advice you were hoping for, but I would get a new one for whichever machine you need it for, and make sure that compatibility with your machine is specifically stated.
Cheers
Nov 10, 2014 | Computers & Internet
I need a power cord for the HP 5590 scanner
Hello alex951,
Welcome, and thank you for using FixYa!
I found a great listing for this power supply you require, on eBay!
Of course it is always wise to use "Top Rated" sellers there.
Here you go!
Power Supply
http://www.ebay.com/itm/24V-AC-Adapter-Power-Supply-HP-ScanJet-5530-5590-5590P-/300566844523?pt=LH_DefaultDomain_0&hash=item45fb2e146b
Happy scanning!
Sep 06, 2011 | HP Scanjet 5590 Flatbed Scanner
I AM LOOKING FOR A LAPTOP BATTERY FOR MY COMPAQ EVO N610C A GOOD LOW PRICE.HI-CAPACITY LI-ION (4400MAH 8 CELLS) FOR COMPAQ EVO N610C
don't waste money on buying second or used.
buy original from near HP store or order online. check HP center near
Oct 12, 2010 | HP Compaq Evo n610c Notebook
I have a alesis dm5 drum module. I have lost the power supply so I bought a universal power supply buti dont want to harm the system. How do i set the power supply up?
NEVER use a universal wall wart supply... it is too easy for the settings to be changed and blow the unit.
It appears that the correct power adapter supplies 9 volts AC at 1 amp (1000 ma)
Most universal adapters supply DC rather than AC.
There are sellers on eBay selling the correct adapters.
Jun 14, 2010 | Computers & Internet
My compaq nw8440 does not power on anymore!
When you say "I bought a new power supply", do you mean you bought a new ac adapter?
Try this method and write back to me with the results:
1) Unplug the notebook and REMOVE the battery pack
2) Hold down the power button for 15 seconds
3) PLUG IN the ac adapter to the wall outlet (DO NOT PUT BACK IN THE BATTERY)
After you plugged in you pc, try powering on the unit again.
If it does not power on, please write me back.
Mar 16, 2010 | HP Compaq nw8440 Notebook
Evesham Nac-cam 7000
Hi
We sell the chargers for the unit. we bought all the stock when evesham went down they are 100% the right one
username on ebay whenitssolditsold
Jun 02, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Compaq Presario V2000 no power new dc jack
I think that this can be rated as solved. If it is not solved please let me know.
May 21, 2008 | HP Compaq Presario V2000 Notebook
Bad ac adapter
Firstly if you have another power lead check that. If that gives the same then read on.
When it comes to laptop power supplies it's easier and more cost effective to replace them.
The parts inside are dangerous, packed in very close to each other and hard to fault find the entire fault. Half the time fixing one fault, you can miss another that is buried under other components.
Try and find an ex-government/ex-lease computer seller etc in your area. They will have another adaptor second hand, or even use things like eBay etc. Just be sure to get things from good sellers, and make sure they are in your country.
If you go back to HP (they own Compaq now) you will be charged an arm and a leg for a new charger.
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Where i can find dell ----1100 inspiron ac adapter???
these are in plentiful supply on ebay.
or just look on craigslist.org
Apr 26, 2008 | Dell Inspiron/Latitude C-Series AC Adapter...
Protron pltv 32 tv
funny that no one's been able to help you, because I accidentally discovered that the power supply cord for my computer worked for my Protron PLTV-32C lcd...  not sure if your model is different in someway, but you may want to try the cord from your own PC first,
and if it works.
Jan 25, 2008 | Protron PLTV-32 Television
Computers & Internet Logo
209 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
