Question about Stairmaster 4100PT Stair Climber
The pedals are hard to push what controls the resistance
  • nnewmanjc Apr 09, 2011
    how do i get wiring diagrams for a stairmaster 4100pt? What controls the resistance on a stairmaster 4100pt?
Clutch pedal of my Sorento 2012 has become very stiff. It is specially very hard to drive in the traffic. Odo meter reading show 560000 km run as of today. what is the problem?
Get your head down on the driver's side floor and look at the clutch cable coming out of the firewall. Push the clutch pedal in and see where the resistance starts and where you start seeing the cable pulled. If it's more than a couple inches before the cable starts pulling, you need to adjust it.
Apr 19, 2017 | Cars & Trucks
The foot control on my husqvarna 545 viking sewing machine quit working. What's going on?
First not familiar with exact product , however troubleshooting is common.
This is if pedal can be unplugged and you have access to volt meter (these are cheap enough under $20 and have other uses to support purchase) , set meter to measure continuity, set meter to lowest ohms to start. Before using on pedal touch the red and black leads together, touching the result should be zero on meter, not touching infinity or blank. Connect leads in various manners to the pins or sockets move pedal. If your meter reads a high number while moving pedal you have an open circuit.
If you see the meter fluctuate as you depress pedal that would be expected ( normal) but then when fully depressed go high ( open) your pedal switch is faulty. The variation in resistance as you push pedal slowly is what varies the speed.
Sep 13, 2016 | Husqvarna Sewing Machines
How to test a cruise control sensor
Check for power then check for resistance when a button is pushed. Each button has a different resistance
Jan 01, 2015 | 1993 Nissan Sentra 4 Door
I have a chevy s10 and the clutch petal is very hard to push
Most likely clutch is worn out, increases pedal height and pedal resistance, recommend replace if around 100,000 miles old. Also good idea to replace clutch master and slave, and service trans fluid.
Jan 05, 2014 | 1998 Chevrolet S-10 Pickup
Adjust a clutch on 2005 toyota echo
CLUTCH ADJUSTMENT:
(a) Check that the pedal free play and push rod play are correct.
(1) Depress the pedal until clutch resistance begins to be felt.
Pedal free play:
5.0 to 15.0 mm (0.197 to 0.591 in.)
(2) Gently depress the pedal until the resistance begins to increase a little.
Push rod play at pedal top:
1.0 to 5.0 mm (0.039 to 0.197 in.)
(b) Adjust the pedal free play and push rod play.
(1) Loosen the lock nut and turn the push rod until the correct free play and push rod play are obtained.
(2) Tighten the lock nut.
Torque: 12 N*m (120 kgf*cm, 8.7 ft.*lbf)
(3) After adjusting the pedal free play, check the pedal height.
Mar 31, 2013 | 2000 Toyota ECHO
Have 90 toyota 4runner just replaced slave cylinder plenty of fluid but the clutch pedal just flops around no resistence either way. any answers?
Hello, try opening the bleeder valve on the slave cylinder, leave it open, pull the pedal up and then pump the pedal down and pull it up repeatedly until you feel some pressure, close the valve and try bleeding the rest of the air out in the normal manner.
Nov 03, 2012 | Toyota Cars & Trucks
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Breaks will not work at random times?
YOU HAVE A BAD MASTER CYLINDER
HAVE IT REPLACED AHD YOU PROBLEM WILL GO AWAY
Mar 02, 2010 | 1995 Toyota Camry
2003 ford ranger There is no resistance in the
right old trick ,with assistant ,who has to be pretty and blonde ,get assistant to push and hold pedal down ,then you go underneath and using a bar wedged in somewhere push the actuator arm in so the slave closes,as you push it in open bleed nut,then assistant lets the pedal up and repeat ,push pedal down and holds it down whilst you force the arm back with bleed valve open ,close valve and blonde assistant releases the pedal.easy when you know how
Jan 17, 2010 | 2003 Ford Ranger Regular Cab
Stairmaster 4100PT Stair Climber Logo
43 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
