Question about Dell 1710n Laser Printer
Hi there, I require to purchase the replacement Photo Conductor (30k Drum Kit) for my Dell 1710N Printer. Can you tell me what Part Number I need to obtain please?
  • 192 Answers
Direct from Dell by clicking this link, otherwise part number is: W5389
Posted on Apr 08, 2011
Testimonial: "I found this useful. But I was told that the Dell 1710n Printer is a rebadged Lexmark E232 Printer and therefore uses 30k Drum Kit 12A8302. Correct?"
  • Chris Apr 08, 2011
    Looking at the part number you provided for the Lexmark, the drum unit does look the same. If the 1710N truly is a re-branded Lexmark E232, then the Lexmark part might work also work in the printer.
    Personally, if what you have is a Dell, I'd buy one using the Dell part number just to be safe. There may be slight modifications made to the PCU so that it will only fit in the brand it is designated for.
My dell 1720 laser printer has 3 black marks down the right side of the printer
Replace the photo conductor unit. It's the pc kit. The drum is damaged. Check to see if it has any silver aluminum showing. This is caused by excessive toner in the waste compartment of the PC Kit.
Aug 18, 2014 | Dell 1720dn Laser Printer
Photoconductor kit? Dell 1700 printer
The photoconductor kit is another word for the drum or imaging drum. All three words refer to the same part.
Here is a link from the Dell site for this model.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=dhs&sku=310-5404
Once you replace the drum, the printer has to be manually reset. If this is not done, the printer will continue to give this print out. By resetting it, the counter is set back to zero. The drum is good for around 30k prints.
From the Online Manual for the 1700, to reset the counter:
http://support.dell.com/support/edocs/systems/1700n/en/index.htm#online_documentation
To reset the counter, press and hold the Cancel button until all lights flash in sequence.
NOTICE: Resetting the imaging drum's counter without replacing the imaging drum may damage your printer and void your warranty.
Jun 18, 2010 | Dell 1700n Laser Printer
Fourth light from the top is on
This light indicates that you will need to replace the photoconductor unit part number :LEXMARK E232,234,330,332 Photo Conductor - 12A8302 (30K)
May 27, 2010 | Lexmark E232 Laser Printer
I change the ink cartage and get the message "the printer has stopped because the photoconductor kit has reached the end of its useful life" what does that mean
The Drum which is a separate part has reached it's end of life. WHen you pull out the toner cart, you press a little button that separates it from the drum. that drum also comes out. You can tell it's the drum becuase of the green roller. You can go to support.dell.com for info on removing the drum if you don't have the manual.
*Note* When you replace the drum, there is a procedure for resetting the drum count. The printer doesn't actually know you replaced the drum. You basically have to tell it. Now this trick will get the printer working right now with the old drum. However, you still need to get it replaced.
THis link will tell you how to replace the drum and reset the count. The directions are for the 1720, however, it will work for the 1710 as well.
http://support.dell.com/support/edocs/systems/prn1720/en/1720_en/en/d0e4183.html#maintaining-your-printer-chapter
Feb 05, 2010 | Dell 1710n Laser Printer
Reset Photo Conductor Kit
Hi!
For step by step procedure to reset Photo Conductor counter please see the following link---
Photo Conductor Counter Reset
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 02, 2009 | Lexmark E450dn Laser Printer
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
Dell 1710n printer problem...
Try resetting the error lights with a drum reset. With the power on and cartridge door open, press and hold the Cancel button until all lights flash in sequence. Release the button and close the door.
Feb 28, 2008 | Dell 1710n Laser Printer
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
1710n Printer - poor print quality
You need to inspect your drum unit as well. If you can line up the marks on your page with the drum then you will need to replace the drum unit. If you donot find any problem with the drum unit then check the fuser unit on the back of the printer. Be very careful when checking the fuser since it is EXTREMELY hot. Good Luck
Mar 06, 2007 | Dell 1710n Laser Printer
Dell 1710n Laser Printer Logo
85 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
