Question about Windchaser Freezer ICM15 Portable Ice Cube Maker - Grey
Am looking for parts for a Mr. Freeze portable ice maker model number MIM-88 water pump will not come on
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How can I find a wirning diagram for a ice maker that has guit making ice but the pump will run?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Your Ice machine does not have a wiring diagram. I have repaired many of these.
1.) Are you getting water? If not it is your pump.
2.) Reach in and feel the cold plate. Is it cold? If not you have a refrigerant leak.
3.) The problem may also be within your main control board.
Unless you have a current service contract these units are considered throw-always. It will cost you twice as much, if not more, to repair it than what you purchased it for, assuming you call a service company.
Go into the following website. Plug in the first 5 numbers on your model number and a list of model numbers will appear. Your model number is incorrect.
Select the model number then click on parts and you will get diagrams of your icemaker. Water Filters Lawn Garden Appliance Parts
Mar 21, 2015 | KitchenAid 18" Ice Maker - Black
Where does the water go in the model IM90 emerson ice maker
open the lid and remove the plastic ice basket. Look on the walls under the ice basket and you should see a "fill line".. Water should be poured into that area (below where the basket goes) no higher than the max fill line.
Oct 21, 2014 | Emerson IM90 Portable Ice Maker
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Magic Chef Portable ice maker is not making ice
I have the same problem as above with my portable ice maker. The water is not getting to the trey for the rods to freeze it. I checked and don't think the tubes have any blockage.
Sep 14, 2009 | Freezers
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
My ice maker has stopped working
The problem is most likely the water control valve on rear of refrigerator.There are two sides on what is called a dual water control valve. If I had your model number I could tell you the part number. The second possibility is the thermostat inside the ice maker is defective. The way to test is to fill ice maker with tap water let freeze and if it dumps and does not refill then the water valve must be replaced. Let me know and please rate my solution, Thanks, Sea Breeze
Aug 13, 2009 | Freezers
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
85 people viewed this question
Top Windchaser Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Windchaser Freezer Expert? Answer questions, earn points and help others
