Question about LG WM-12230FB Front Load Washer
My washer wont rinse or spin SE keeps coming on
    Genius:
  • 1,400 Answers
Hello
LG washing machine error code SE indicates a "motor fault.
You can try resetting it by unpluging the unit for 3 min and see if it clears.
If not, it s going to need service.
Posted on Apr 08, 2011
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
Jun 10, 2014 | Brandt WFH1176 Front Load Washer
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Washer stops agitating durning the rinse cyle, but timer keeps going. Also won't wont spin the water out on the rinse cycle. Wash and spin work just fine. This problem is the same on all three cycles.
I suggest you replace the control box. I need Mgfr & model # to find the part number for you. The replacement steps are more mechanical than electrical. Oh! make sure you UNPLUG unit before starting repair.
Feb 11, 2010 | Washing Machines
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
LG WM-12230FB Front Load Washer Logo
403 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
