Question about JVC HR-XVC1U DVD Player/VCR
Hello-- I believe the remote sensor in my unit is
Hello-- I believe the remote sensor in my unit is not working. What is the best way to solve the problem---try to repair or replace? Where to purchase?
  • JVC Master
  • 467 Answers
Remote sensors are fickle beasts; and they can develop weird characteristics in any appliance, but they seldom fail completely. It is usually the circuit behind it which can fail, in particular, the function control IC (this IC is easy to locate on the board as the sensor is directly connected within close proximity to it).
When this circuit fails or it becomes weak, the unit no longer receives the correct pulses from the remote. It can be a fiddly repair job, add the cost of parts to that list, and it becomes expensive and time-consuming. You may be able to locate a replacement IRD from an electronics store, which will fit/work like the original did - note its pin orientation and voltage rating (IRDs are voltage rated, typically around 5V), as for the function control IC, unless you note the original's part number, this could prove impossible to obtain.
My guess is that for you it is simply a faulty IRD (or IR receiver) - if you can obtain the right one for your model, it should be an easy repair. It may or may not be soldered directly to the board. Hopefully you do not need a new function control IC as well.
Fingers crossed for you on this one.
Posted on Apr 08, 2011
Cannot turn unit on with remote
the problem lies between the remote sensor of the unit or the remote control itself.
You need to test the remote with another unit or test another remote with the unit to actually confirm where the fault is coming from.
Regards.
Jan 05, 2012 | Sanyo Split System Air Conditioner
KLV37U-300A Sony BRAVIA Flatscreen TV. TV does not respond to its remote. Remote sends signals (when remote aimed at digital cam I can see the lights go on). Believe sensor on TV not recognizing remote...
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Good luck.
Feb 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Remotes will not work
change sensor of your remote control ,if there is not solve than change your sensor of your tv
Jun 02, 2010 | LG 42PG20 42 in. Plasma HDTV
Not functioning on my tv sensor
need nmore info then that. are u saying that the remote control is not working with the tv or are u saying that the controls on the set is not working . ok lets say the remote is not working 99 times the problem is the remote control unit. the best way to find out is. if your tv is a newone 1 -2 years old u could take the remote to best buy and see if it will work on a nother tv set there. if not it is your remote problem solved.if it does work then i could be the sensor but u need a scope to see the rf signal from the sensor i have only change 2 sensers in my 30 years working in electronice service field. let me know marty
Oct 13, 2008 | Televison & Video
SRT2232S 32" will not respond to any remote control
There are 2 reasons of this problem, check TV remote control, is it working or not?
2nd reason, there can be dust in your TV, aspeacially in front of remote sensor, this can be the cause of No Remote Signal Receive.
Jul 27, 2008 | Sylvania SRT2232S 32" TV
Samsung AS12ABMC A/C (about 3 years old)
heres a clever way i use to check remotes are working. put your mobile phone into camera mode and point your remote control toward the camera while pressing any button.if working you will see a blue light emiting from your remote on phone screen.
Jul 08, 2008 | Samsung AS18A6RB Air Conditioner
Digits dropped while changing channel
Make sure that you have the correct DTV box selected on the Tivo unit in the Guided Setup.
Make sure that the IR cables are directly in front of the IR eye on the Tivo.
Jun 07, 2008 | Philips PTV100
DNX7100 Remote inop
The problem I had was with the remote control unit for the steering wheel controls. It shorted out. The head unit was fine. But, when the sterring control unit is shorted it also prevents the hand held remote from working.
Jan 01, 2008 | Kenwood DNX7100 Car Video Player
JVC HR-XVC1U DVD Player/VCR Logo
200 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
