Question about HP Officejet 4355 All-In-One InkJet Printer
Copy, scan and fax not working. after alignment cartriges, which we can't complete its say busy. cartriges are new. should we reinstall from the begining?if so how can we get english speling. this printer we got 1year ago in australia new and we have all with it like; cd,book. would be happy if you can help us.Andrei &Elena Antonov Thanks
MUKHTAR
  • 2017 Answers
SOURCE: Print product alignment
just scan the alignment page and complete the process it will not promt you do again. bye
Posted on Sep 22, 2007
map9966
  • 2351 Answers
SOURCE: printer problems
Re-install your HP driver software
Down load and run HP's Software Cleanup Utility.
Please read the instructions first.
Download here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00036626&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
Posted on Dec 04, 2007
SOURCE: SCAN,COPY,FAX PROBLEM
unable to scan,copy or send a fax.I can copy from desktop help R.FARDA
Posted on May 16, 2008
rakeshpramod
  • 234 Answers
SOURCE: Scanner Failure, 'Power off and on' message - therefore, fax will not work
Scanner failure will not let you to make copies nad scan but you will be able to print from computer and receive fax.
Even then try the steps mentioned bellow:
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector (If possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing Printing from computer,
If you are able to print from computer you should be able to receive faxes.
Try printing a test fax.
Press Menu/Setup> Then press the right arrow key to locate Tools> Then Press Ok> Again press the right arrow key to locate Run Fax Test> And press OK
Check to see if it prints a Fax test
Good Luck
Posted on Oct 03, 2008
  • 1015 Answers
SOURCE: I did not get a manual with my HP Photosmart
http://www.hp.com/#Support
You can download the manual and installation software from their site. You will need to enter the model number.
Posted on Sep 05, 2009
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer does not respond to "Copy" command
Press and hold the Setup button, and then press Options (or Copy Options ).
It will bypass the alignment.
Apr 09, 2010 | HP PSC 2175 All-In-One InkJet Printer
Continuous Alignment Message, Please Wait.
Click here and follow the instructions to do a partial reset on your printer and try to align cartridges. Click here for instructions to align cartridges.
Jun 08, 2009 | HP J3680 Officejet All In One Printer
No printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
May 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
How do you align your printer
WTF...wheres the solution. Bunch a ****!
Oct 14, 2007 | Lexmark X2470 All-In-One InkJet Printer
Reformatted computer worked while now recives faxes wont print
Uninstall all of the software and go to this link http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:439:0:0 install the updated version of your printers software and let me know what happens.
Jul 19, 2007 | Lexmark X4270 All-In-One InkJet Printer
Jun 25, 2006 | HP PSC 1210 All-In-One InkJet Printer
HP Officejet 4355 All-In-One InkJet Printer Logo
176 people viewed this question
Seeker5211
Seeker5211
