Question about Acer AL1706AB LCD Monitor
Acer al1706 does not turn on shows ascreen for one second then black is there a lock i don't know of.
    Problem Solver:
  • 6 Answers
Open and look at the tops of the capacitors. I bet there are at least 2-3 "bulging" tops. Replace them and the problem WILL be solved;.
Posted on Apr 08, 2011
The screen is blinking too fast to do anything I am on another computer now how can I fix it?
inputs are wrong. use the proper cable. Set up your video to extend displays. Change resolution.
Mar 31, 2014 | Chief Manufacturing Chief Flat Panel Dual...
Whenever I turn off the monitor for the night, in the morning I'll try to turn it back on, but the power button just flashes green every couple seconds. It takes about 10 minutes of this, then my desktop...
It sounds like you have dying power supply due to bad caps just like the rest of failed ACER and all other brands as shown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 09, 2010 | Acer AL1706AB LCD Monitor
ACER AL1706 powering up, green power light flashes once a second, faint 'flicker' on screen, eventually starts up with the Acer logo, and runs normally.
You may have dying power supply due to bad DC filter caps.
Please see failed ACER and other monitors to see if you will want to DIY repair.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
Aug 28, 2010 | Acer AL1706b 17"LCD Monitor
I have an acer AL1706 with a flashing power led.
First place to check will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 10, 2010 | Acer AL1706AB LCD Monitor
I have an acer al1706 lcd monitor. it won't turn on. the power light is blinking every 5 seconds.
This is generally indicatve of bad capacitors in the circuits. Take it to a reputable repair person or check my website www.micromendllc.com
Feb 25, 2010 | Acer AL1706AB LCD Monitor
At start up the AL1706 monitor stays black and the green light blinks on and off. I have to restart four or five times before it eventually works
cyndommett, If not into repair work, and can afford trade for new, GET NEW ONE if current AL1706 is 4, 5, 6, years old. To understand your monitor's problem, spend an hour or two reading my and other lcd monitor tech's FIXYA profile's and testimonials. Then and only then will you have a handle on what options are at your disposal and the reason why your unit has FAILED. Bye for now. 12fixlouie
Feb 19, 2010 | Acer Computers & Internet
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1706AB LCD Monitor Logo
327 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
