Question about Cell Phones
Getting very hot after connected for 20-30 minutes
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
Hi there!
are you using original battery for your cellphone? and original charger too? local batteries have that overheat issue. if you are using battery and charger thats both original (if your phone is nokia, your batt and charger should be original nokia aswell), bring the phone to your local technician before you overheat it. if its still in warranty, they can replace either the battery or the unit for you. cellphones do heat up when being charged but if you say its very hot then have it checked by the store or a technician.
Posted on Apr 08, 2011
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Why my keeway outlook is getting to hot
The only thing I can think of is a bad connection behind the key switch it could cause a fire so you need the fix it ,just un screw the switch and clean all connection points mind grease them to stop them oxidising best of luck
Jun 06, 2014 | 2010 Keeway Outlook 125
Need driver for canon LiDE 20,30 to run with windows 7
Here you go:
http://usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_20#DriversAndSoftware
Just choose that O.S. and you're set.
Hope this helps!
Remember to Thumb me Up lots for all the hard work! :D
~~Dayminner
Jun 03, 2011 | Office Equipment & Supplies
Is this tool known to get hot?
We have two of these at my work. It becomes very hot to hold after only about 4-5 minutes of running. And I do mean "hot"--hot enough to make the body distinctly uncomfortable to hold, and hot enough for me to worry about soldered connections inside melting. Connecting a dust hose to my 2 1/2" shop vacuum helps cool it a bit, but merely enough to double the run time to about 8-10 minutes. Then I set this sander aside and let it cool down for about 15 minutes before using it again. Yes it is known to get hot
Feb 23, 2011 | Porter Cable 371K Factory Reconditioned...
There seems to be a flow problem. The pressure starts out fine and ends up a trickle but only on the hot side. I have used the T & P valve to try and back flush the unit , to no avail
In order to clean the unit you need to connect a small sump pump to the cold inlet, and run a hose from the hot side into the same bucket. Pour about a gallon a white distilled vinegar in the bucket, and turn the pump on. Let the solution run through the unit for about 15 minutes, then reverse the hose connections and run the pump for another 15 minutes. Reconnect the water supply and outlet. Turn the water on in the bathtub first on the hot side and let ir run for a few minutes before turning the power back on to the heater. While the water is still running turn the power back on and reset the thermostat. If you get a lot of debris in the bucket, you may need to consider installing a water-softener to prevent scaling.
Sep 17, 2010 | Bosch & Tankless LP Hot Water Heater
How long does it take to reheat water when gas bottle runs out and then you switch to new bottle ?
water getting hot should be almost instant... it may take a minute to move the cold out of the pipes.
is your heater ignighting?
if not then you might have a small amount of air in the gas line when you changed the bottle.
you will need to bleed the line...
with the gas turned on, loosen the gas connection to the unit and let the air out until you smell gas.
tighten the connection, snug, do not over tighten.
wait about 5 minutes for the gas to dissipate before attempting to light the unit.
during this time, you can use a little soap water on the connection you loosened to make sure it is not leaking.
now go turn on your faucets, let the water run for a minute and make sure you get hot water.
if no hot water, then you might have something else wrong. you will need to let us know the error code and what the unit is doing
Aug 11, 2010 | Bosch & Tankless LP Hot Water Heater
Brake light switch 1992 Chevy Lumina with cruise control
just look above the brake padel, in front under the dash it have two bolt,10 or12 mm. remove bolt take
out wire harness then reverse watt you did then you
put it back easy to do about 20,30 mi.
Apr 08, 2009 | 1992 Chevrolet Lumina
My dryer will not dry,eventhough the dryer gets hot
Your exhaust vent on the rear or the connecting vent to the outside if blocked with lint.
Remove the vent from the rear of the dryer and run a timed load at 40 minutes.
If it is dry your problem is with your connecting vents.
Mar 22, 2009 | Maytag Dryers
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Cell Phones Logo
65 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
