Question about Mitsubishi CP3020 Thermal Printer
I'm getting a small line in all my prints... I have blown out the printer compartment arear..... what else can I do....
  • 1,218 Answers
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Posted on Apr 08, 2011
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
The power does not come on when the "On" button is pushed. What's the problem?
Hi:
Check near the power input connector for a small fuse compartment, the line protect fuse may be blown and in need of replaceing. If there is none then the power supply is not getting power the fuse may be internal to the unit. Or the pwr supply has failed entirely, but check the simple solutions first, usually no power is due to the printer being plugged in an switched outlet or blown fuse or power supply failure.
Aug 24, 2010 | HP LaserJet 5si mopier Printer
Voids when copying
voids or arears of no print could be two things. moisture in paper. try fresh paper out a sealed packet. two- the developer is at fault on needs to be topped up or replaced
May 05, 2010 | Office Equipment & Supplies
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
HP laserJet 6L printer making noise/not printing correctly
The problem with the screeching sound and horizontal lines printing is no lubricant for a small motor, not the main motor. To fix this problem, download the service manual which shows how to remove the case. You’ll need a phillips screwdriver and some machine oil or something similar to Z-Max. When the printer is apart and you’re facing it, on top there’s a compartment with a metal cover plate (shield) held by two screws. To the left is a spring loaded switching system that rocks into position when it’s called, and presses on the tab of a leaf switch. With the printer plugged up, you can press on the leaf switch which will engage the printers system, causing the printer to attempt printing. During this you’ll hear the screeching sound you’re describing. This is your test procedure during this repair. Next, notice the two multi-wire connectors at each end of the compartment. One bundle runs across the top of the compartment and connects on the other side. Remove both connectors and the two screws that hold down the shield; one holds down a metal pressure tab, also to be removed. This releases the shield exposing a small circuit board that has a control IC and a small motor. Three screws holds this circuit board to the printers plastic casing. Taking care not to handle the circuit traces (IC Static Protection Protocols), remove the screws and remove of the board. On this board is a small motor with it’s flywheel held down by a square weight and a pressure tab. Remove the top tab and the weight, turn the plastic guide to the side, and lift the flywheel away from the motor. Apply the lubricant to the shaft of the flywheel and reassemble the system. Try your switch test. Chances are, it’ll work without all that screeching. If you get that far, trust me, it’ll print. The "finge"
Sep 27, 2008 | Office Equipment & Supplies
Scratch on print
Sounds like dust within the front compartment. Remove the ribbon AND the paper roll. Give the unit a blow out with compressed air. Also wipe the print head with an alchol wipe.
Jun 02, 2008 | Sony UPDR150 Thermal Photo Printer
Will not print ink
Take off the rigth side of the printer it snap off used a plain screw driver and pliers be careful taking it off.
Pull the whole plastic ink compartment out .
Take off the two tubes going to a small hub clean the black tube about three inches long. Then clean the clear tube with a green line on it. Put every thing back. Good Luck
Apr 24, 2008 | Epson Stylus C86 InkJet Printer
Printing issues
I would get it repaired. you could get one off ebay. they are a lot of money new.
Mar 21, 2008 | Epson Stylus Photo 1280 InkJet Printer
Printer problem
During a normal scan, the light source moves across the large glass pane reading the entire area. When using the ADF, the light source remains stationary below the small small glass pane to the left. Check for smudges or specs on this glass area. We had the same problem, and cleaning the small glass pane worked.
Mar 08, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Mitsubishi CP3020 Thermal Printer Logo
203 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
