Just brought a bush mpk4099buk mp3 player,great kit for the money but i cant find any sound/volume controls and volume is set quite high so wen playing through car radio distorts very badly, surely there must be volume control on a mp3 player,Please advise me, would be much appreciated kind regards Martin Abbott
SOURCE: i cant find a volume
Hold Play/ Pause button and then press Previous/ Next button to volume up/ down.
Posted on Dec 27, 2010
techman
  • 3130 Answers
SOURCE: Audio Problems With MP3
First thing you wanna do is to try another set of headphones. If it still sounds muffled then theres a fault in the audio output section and these things are non user serviceable. Your gonna need to send back to the manufacturer. Good Luck
Posted on Apr 27, 2006
SOURCE: Sandisk MP3 player SDMX1 - bad headphone connector
I have the same trouble. I ended up taking the 3 screws out, then I used a flat screwdriver to pry open the end pieces. Note from the top that there is a line where the end pieces connect. Pry off both end pieces - then you can separate top and bottom. HOWEVER, once you get in, it will be apparent that this is not very hacker friendly in there. There is a daughter-board with the microphone and headphone adapter and its epoxied in there. If anyone is successful in determining how to fix the headphone jack, please add!!!
Posted on Jan 02, 2007
SOURCE: barbie girls mp3 player
You have a round button on your Barbie Girls Mp3 player. Right? Well, you have a round button in the middle of the circle that is Pause. On the right and left hand side is the back and forwards buttons. The up and down buttons on it is the volume control. Up is louder. Down is softer. Hope that helped you, deary.
Posted on Oct 20, 2009
SOURCE: Sony walkman nwza 818 volume control button wont
My Sony MP3 player's volume control button wont turn up! I press the plus button on the volume control located on the side of the mp3 player and it does nothing yet i can still turn it down! Please help
Posted on Jul 06, 2010
My Bush MPK4099BUK wont charge or go on at all
Hi, if it won't charge at all , Replace the battery of the same kind. Good luck.
Jun 20, 2011 | Audio Players & Recorders
Just need to know how to turn up volume on it
Click your start menu, open control panel.
Go to "Sounds and Audio Devices".
Click on the "Volume" tab. There is a volume bar in the "Device Volume" pane.
Click and drag the volume tab toward the "High" or "Low" position.
Click the "Apply" button to save your new volume device settings.
May 13, 2011 | Coby MP620 MP3 Player
I cant find how to put the volume up, or lower it. How can i do this?
Go to "Start" and open the Control Panel.
Double-click on the "Sounds and Audio Devices" icon.
Hope this helped. Thank you for using Fixya
Please rate this answer
Apr 27, 2011 | Coby MP620 MP3 Player
I got ny Vega mp4 player and i just loaded on some music on it and i cant find the thing to raise volume !!!!!!!!!!
it depends on the model of your mp3 if it has a side volume controller then it may have speaker problem but if it did not have side controller then increase the volume from the volume setting of player
Dec 25, 2009 | Umax Vega108 MP3 Player
The volume of my mp3 player sony E436F is too much low. Can I to high...??? Is there any solution???
Hi rockgfr,
The first way to increase the volume is of course by the volume control on the right hand side of the player. If even at the highest limit (30) provided by this control, the volume seems low, then go to Settings --> Common Settings --> AVLS. The volume limit is probably on, so you can try putting it off and see if you can increase the volume further. Failing these methods, you can always use software like MP3Gain to raise the volume of your tracks.
Nov 04, 2009 | Sony NWZ-E436F MP3 Player
Volume control problem
Your volume control switch in the cirucit is damaged - call Philips and find out if you are still in-warranty.
-Tha Mp3 Doctor
Feb 22, 2009 | Philips HDD1630 MP3 Player
No sound coming from my ipod
First, check to make sure the volume is up. Also check the volume limit and make sure it is set high enough. If it is and you still can not hear it, you might need the headphone jack repaired at a shop.
Nov 15, 2008 | Apple iPod MA446LL/A MP3 Player
Sansa e200 4gb mp3 player
If the menu option does not appear, then there is problem with your player's software - try a firmware upgrade to get a version of the software that will hopefully contain the menu item
May 24, 2008 | SanDisk Sansa e200 MP3 Player
My mp3 does not play very loud through speakers
Did you check the settings in the info section? thee is a setting for volume there
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
221 people viewed this question
 Grubhead
Grubhead
