Question about Toshiba RS-TX20 DVD Recorder
I bought one of these years ago and real quick power on/off blip. The unit would not reset and now there is a dvd stuck in it. I called Toshiba, years ago and they said I'd have to send it in for repair so, i stored it away. Now I'm looking at aal the HD dvd's i've recorded and I'm looking for advice on this thing. In my opinion this thing must be pretty fragile to get damaged by a quick flash in power, I guess if a transformer blew close by but, i didn't hear anything and, it wasn't a storm. What little info there is left on this thing indicates that a dvd stuck inthe unit could cause the same problem. Are any of you guys familiar enough with this unit to advise me? In other words, have personally seen this kind of thing with this particular model. I haven't taken it down yet but, I'm going to soon and I'll be messing around so the input will help.
  • Toshiba Master
  • 467 Answers
Unusual, but not uncommon for a power surge to damage the switchmode power supply in this unit. Repairs could prove very expensive and/or uneconomical for what is now an older model DVD recorder, but you can always submit it to an authorised Toshiba service centre, obtain a quote on the likely costs involved to restore this to original working order, then you can make a firm decision afterwards on the economics of fixing this or not - up to you.
Having said that, the PSU may or may not be severely destroyed by the surge. It depends on how many components were affected which determines the cost. In many cases, the workshop may be able to order in a replacement PSU board, fit it, check the machine out, and charge accordingly.
It is easier, quicker, and in nearly every case more reliable to replace an entire board (refurbished or new if available) in an appliance.
If you do send it off for repair, don't forget to mention the disc stuck in it and you would like that disc returned to you along with the repaired unit. Most workshops are honest, but mention the disc anyway just in case. Good luck.
Toshiba is generally a reliable brand and they make good products, and they fail like everything else over time, but in your case, the surge was most likely as a result of poor voltage filtering in the power supply.
Posted on Apr 08, 2011
I have two SONY RDR-HX750 DVD Recorders that I haven't used for a couple years (I've been using my TOSHIBA and MAGNAVOX DVD Recorders with Hard Disk Drives instead). Now when I try to play a DVD or play a...
have you tried resetting both machines, also if they where stored somewhere cool and then brought into a warmer area it may just be condensation, if this is the case leve the machine to acclimatise for an hour first.
To reset power up and remove all discs, then press and hold the Stop button on the machine and then press the power button, the unit will power off and will be reset to factory default.
Dec 06, 2013 | Sony RDR-HX520 DVD Recorder
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
Samsung DVD-4600 won't record with VCR timer set
Press fast forward and rewind button on the unit simultaneously for 10 seconds with no disc inside the player to reset it to factory setting.
Aug 19, 2009 | Samsung Televison & Video
I HAVE A MINTEK 5" (I THINK ) DVD PLAYER MODEL#5860....I CANT GET THE BATTERY OFF THE TOP OF THE UNIT....I RECIEVED NO INSTRUCTION BOOK(BOUGHT ON E-BAY)AND I NEED YER HELP.....THXS
I bought one at Best Buy for my daughter a few years ago. I'm glad I bought a psp for it to replace the battery.
They haven't had a good reputation. The consumer product safety comission recalled a battery from a unit they made three years ago after reports of it catching on fire. It was a different model than the one you have.
The model number should be a an MDP-5860.
Here is a source for batteries and power supplies for that model
Jul 16, 2008 | Mintek Televison & Video
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Sp k-970 dvd player will not play. played 1 dvd whenfirst bought now will not play any
1) Reset DVD player by powering unit off and unplugging from wall outlet for 30 seconds, then try again
2) Run a DVD cleaner
Are you getting a "No Disc" Message no matter what disc you use? Are you getting the message no matter what type of disc you use - commercial DVD vs burned DVD? If you are only having problems with burned DVD's, then make sure the discs are finalized.
Is the TV on the right channel?
If all else fails, call the manufacturer.
May 26, 2008 | Toshiba Televison & Video
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
Dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Sep 16, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba DVR recorder incorrect disk message
I find when my unit gives that same message, if I unplug it for a few hours, the memory resets itself. You may have tried this already, but it does work with my machine. tcast at yahoo.com
Jan 28, 2007 | Toshiba DR4 DVD Recorder
Toshiba RS-TX20 DVD Recorder Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
