Question about JVC KD-S23 Car CD/ MP3 Player
The wires from the back of the stereo were cut and im not sure what wire goes t what wire cuz there all different colors and no to match
    President:
  • 676 Answers
This should help you out. Good Luck.
Posted on Apr 08, 2011
Speaker wiring diagram for a 08 dodge 2500 truck with 7 speaker infinity
Never have found good wiring diagrams for stereo's. Bought them and color codes didn't match. I have mitchell and alldata at work, they don't match. I wire them in with a volt/ohm meter. I find B+, Then hook ignition the the heater control wire. Ohm out the speakers. Thing is, you have infinity. You'll have to find the amp and cut the speaker wires and patch them there also, first. Just a note.. All speaker wires are twisted/paired wires. Cut the tape back 4 to 6 inches to find them. Another note. The speaker wires from the stereo to the amp will be a set of colors. From the amp to the speakers will be different colors.
Nov 01, 2016 | Dodge Cars & Trucks
I try to put a CD player on my 95 doge dakota with out harnes an sens then it looks like I don't have ground I don't know what's going on?
The power wire is always red so check that out. N if u dont have ground, look for a simple metal surface that u can put the black wire to cuz thats ur ground. N as for no power check your fuses u might have touch to wire together that made a spark.
Dec 01, 2012 | Cars & Trucks
I have a 97 toyota corolla, my father had givin me his old radio, earlier today my car radio lit on fire almost torching my dash board, im a trained firefighter so i know how to put it out. unfortunatly im...
OK, first I recommend you purchase a wiring harness specific to the vehicle. The wiring harness is equiped with standardized wire colors to match aftermarket radios. Then the harness plug situates the wires in the correct pattern to match the vehicle. All you do then is plug it in. You will probably need a trim panel too. I recommend you check out www.crutchfield.com, they have the harnesses, dash kits, and instructions. Hope this helps.
Aug 29, 2011 | Car Audio & Video
To hook upa cd player after they have cut the factory plugs! there r 2 different ones. one clip has eight speaker wires abd the other clip has six wires! what wires do i hook togater to make it work?
your stereo should have come with a wiring diagram for it that at least tells you what color wire is what coming out of the stereo just match up the colors/signals per this chart: This for for a typical ford- http://www.installdr.com/Harnesses/Ford-Wiring.pdf
Feb 28, 2011 | 1995 Ford Contour
My car stereo was stole they cut the factory wiring harness from the durango i need to know the color codes of the wires please
That's hard to answer cause it depends on how far back on the wire harness they cut. Plus if you have a Bose system or not. I would highly suggest to take it into a stereo install shop to at least check it out but maybe install the new stereo.
There is a wiring color code that all vehicles use but if the wires have been cut to far back they will be different colors. If you have a factory amp then you will have to rewire for the speakers to bypass it.
I added below the color code. Make sure you disconnect your battery before you start wiring anything.
Please note: You can do major damage to your truck computer and other components if you wire it wrong.
Proceed at your own risk
moz-screenshot.pnghttp://i.ehow.com/images/a05/32/br/hardwire-car-stereo-800X800.jpg
Feb 26, 2011 | Dodge Car Audio & Video
I have a 93 jeep grand cherokee and the wires on my sony cd player dont match up and i dont know what the right way should be
Im quessing you are trying to install a sony radio into your jeep. The question is do you still have a plug on the wires in the dash? Or has the plug been cut off? If you still have the plug-you can buy a wire harness from Best Buy or Crutchfield or any car stereo shop that will match the wires for you. If you need more info on how to install this radio without the harness, e-mail me cuz it's alot of typing for nothing if you don't.
Sep 13, 2009 | Car Audio & Video
1997 kis sephia wire harness
you can get a repair manual at your local parts store it will have your diagram you need !
Aug 08, 2009 | 1997 Kia Sephia
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Car stereo switch out
Ok, first off, NEVER CUT WIRES!!!! what you need to do is go to your local audio store ie. best buy etc. buy a wire harness. It makes everything so simple, just match colors. If your wires are already cut, then you need a haynes manual about $15.
Feb 10, 2009 | Alpine CDA-D855
The wires for the stereo are cut
Yes this is not to bad to deal with.. make sure you use quality wire connectors so you don't have problems later with bad connections. you pretty much just have to match the colors from the harness in the car to the ones on your deck. If you don't want to cut off the harness connector on your deck just purchase one that you can connect to your deck and cut the wire ends on the other side of the adapter. The only wires you wont be able to match color for color is speaker wires... for these you will just have to hook them up temp. and test to see that they are connected to the proper speaker output. close.gif Read more >> Options >> answers-logo.gif
Aug 24, 2008 | 1991 Pontiac Sunbird
JVC KD-S23 Car CD/ MP3 Player Logo
136 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
