Question about Xerox Phaser 6130 Laser Printer
La impresora phaser 6125 despues de calbrar envia 2 pagina de printer settings y el error 061-370
  • 2072 Answers
SOURCE: XEROX PHASER 6180 LASER ERROR
That is a laser fault. You should have a 1 year warranty from Xerox on that product. Call 1-800-835-6100 have your serial number ready.
Posted on Sep 04, 2008
Dadofmykids
  • 25 Answers
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Posted on Apr 07, 2009
wrinaldo
  • 185 Answers
SOURCE: tengo 2 impresoras xerox phaser 6110 las cuales me
The black toner 106R01274 may be bad or empty. Try replacing that first.
It is possible that the Image unit is bad also 108R00744
Whit
Item, Inc
Posted on Oct 21, 2010
  • 42 Answers
SOURCE: la impresora phaser xerox
Vuelva a colocar el cintur?n de la unidad de transferencia
Posted on Jan 17, 2011
SOURCE: Today when I wanted to
An internal error has occurred. Turn the printer off and on. If the problem is still there the laser needs to be replaced. If the machine is less than a year old then the machine will be fixed under warranty.
Posted on Mar 04, 2011
Tengo una impresora brother dcp 130c me da error 43 me pueden ayudar
Aqu? est? una lista de art?culos que pueden estar causando el problema 1. Hay un conflicto dedispositivos en el equipo que la impresora deja de funcionar despu?s de un per?odo de tiempo determinado. Esto se conoce como un conflicto decontrolador de dispositivo 2. El cable detransferencia de datos USB 1.0 y no 2.0 que esto puede causar problemas de transferencia de datos y hacer que el usuario tenga que volver a instalar varias veces 3. Su equipo tiene el softwaremal instalado para HP 4. Por ejemplo, si ha actualizado recientemente a Windows 7 o incluso degradado a Windows XP, elsoftware tendr? que cambiar junto con el sistema operativo. Prueba estas soluciones a cabo antes de determinar si se trata de un problema real conel hardware de la impresora
Jan 23, 2011 | Brother DCP-130C InkJet Printer
La impresora canon ip4600 no reconoce los cartuchos. al encernderla parpadea las luces y sale el error 6502
C?mo restablecer el c?digo de error "6502" para CANON iP4300 ip4600? tal vez los siguientes consejos pueden ayudarle:
Con la impresora desconectada, retirar el carro de tinta a la derecha, Enchufe la impresora, presione el bot?n POWER, No suelte el bot?n de encendido, y luego presione el bot?n RESUME dos veces seguidas. Suelte el bot?n POWER, pulse el bot?n REANUDAR 4 veces.
La se?al ac?stica puede sonar una vez. Luego, con la impresora desenchufada, despu?s de que restablecer la unidad electr?nica de la impresora, abra la impresora y este proceso ha terminado.
Listen Read phonetically
Dec 14, 2010 | Office Equipment & Supplies
MARCA ERROR 0xc18a0506 TRAE TINTAS NUEVAS :s
: Realice por favor el debajo de pasos: : 2. Apriete y suelte el bot?n de flecha hacia la derecha hasta que la presentaci?n diga "Men? de Configuraci?n de Sistema". 3. Apriete y suelte el bot?n "bueno". 4. La presentaci?n debe decir "estatus de fracaso de Hardware". Si no all? ya, Llave de Flecha sobre a "estatus de fracaso de Hardware
: 5. Apriete y suelte el bot?n "bueno" : 6. La presentaci?n debe decir "estatus de fracaso de Hardware: Vac?e. Apriete bueno vaciar". 7. Apriete y suelte el Bot?n "bueno". El mensaje cambia a "estatus de fracaso de Hardware Vaci?. Prensa Cancela para continuar". 8. Apriete y suelte el "CANCELA" bot?n como muchos veces como sea necesario, para que, o el "bienvenido a Photosmart Exprese" pantalla parece, o, el "Fracaso de Sistema de Tinta" pantalla parece. POR FAVOR no TRATE de IMPRIMIR EN ESTA ETAPA. 9. Utilizar el Bot?n del Poder, apaga la unidad y desenchufa el cable de energ?a el?ctrica de la espalda de la salida de impresora y pared.
HPRepDude: As?gurese de que realiza pasos de 2-9 y permiti? que sepa el resultado. El cliente: Visto bueno. Todo fue como si los pasos dijeron y ahora son apagado y es desenchufado. HPRepDude: 10. Espere 30 segundos para el poder de ser descargados y entonces tapan el cable de energ?a el?ctrica en la salida de pared primero y entonces en la espalda de la impresora 11. Encienda la unidad. La impresora puede demostrar mensaje "BOTON de PODER de USO Al CIERRE LA IMPRESORA" seguido por "visto bueno de PRENSA para CONTINUAR". Apriete bueno. 12. Si la impresora ya ha inicializado, entonces va al pr?ximo paso. Si no, la impresora comenzar? el "UN PROCESO de INICIALIZACION de TINTA de TIEMPO". Permita este proceso para completar y no interrumpir. Una vez que el proceso de inicializaci?n es completo, la impresora imprimir?
una P?gina Diagn?stica. 13. Para verificar impresora funcionalidad imprime una AUTO PAGINA de PRUEBA. : Realice por favor todos los pasos antes mencionados de 10 a 13.
Nov 24, 2010 | HP Photosmart C6280 Printer
Asistente para instalar
Hola.
Antes se necesitan descargar las controladoras para la impresora.
Para descargar las controladoras (drivers):
Pinche aqui para abrir la pagina de suporte Canon.
En la pagina de Canon eliga su sistema (version de Windows, Linux o Mac) pinchando Select OS.
Siga las istruciones, descargando el file, y ponendo el file en execucion (RUN). Mejor dejar el cable USB de la impresora desechufado mientras que descarga y instala el programa. El programa mismo pedira de enchufar la impresora durante la instalacion.
Aug 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have a Samsung that say Transfer Belt Error
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
PROBLEMA IMPORESORA EPSON DFX-9000 ERROR 3
Aprendizaje hablar español
ERROR 3 - Carriage Return Horizontal Position Error
The SP motor brake signal did not switch ON within 3 secs after turning the printer ON.
La señal del freno del motor del SP no encendió en el plazo de 3 secs después de girar la impresora.
Check SP motor connection or call for service.
Compruebe la conexión o la llamada del motor del SP para saber si hay servicio.
Aug 29, 2008 | Epson DFX-9000 Matrix Printer
Xerox Phaser 6130 Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
