Question about HP LaserJet 8000n Printer
The LCD menu read out is lit with "Ready" but I cannot print out the Config page in order to find out the IP address of the HP 8000n so that I can set my TCPiPort with the IP address so that I can print.
    Guru:
  • 352 Answers
I Found this on another website for you
    "Press the MENU button until Information Menu appears on the display. Press the ITEM button until Print Configuration or Print EIO Pageappears in the display. Press SELECT"
If this information is useful please rate this response Thank You for supporting the FixYa Community
Regards GM
Posted on Apr 08, 2011
Ip address?
Switch power off. Make sure the network connector is connected to the printer, now, hold the green(go/print) button whilst powering the printer up continue to hold the green button until the display has lit, wait until printer is ready and it will now print out the configuration page which has the Ip ranges listed
Jul 22, 2014 | HP LaserJet CP1215 Color Printer
I just moved my computer around to another room and instead of hooking it up to a switch box so several computers could use it I hooked it up only to my computer with an Ethernet cable directly. Now the...
Print a config page and check the IP address.
On the PC right click the 4050, go to properties, go to ports.
Make sure the IP address is the same as the printer.
Also on the rear of the printer, make sure that the green light on the JetDirect is on.
Check the config page (the 2nd page) right below the EIO X - JetDirect heading.
It should say "I/O Card Ready"
May 05, 2011 | HP LaserJet 4050tn Printer
I need to find the IP address of my HP Laserjet 4200n printer. I've gone through all menus, printed a configuration page, and nothing. How can I find it??
First look at the back of the printer where the network cable plugs into the formatter. There should be a blinking green light. No green light no network!
That means printer is talking to the host.
Print out the config pages again. On the 2nd page top left side should be a line "I/O card Ready"
If it is READY, look down the page and you should see the IP address.
You can also push the left side of the menu switch twice. You will see EIO X JETDIRECT MENU
That is where you find the IP address.
Apr 19, 2011 | HP LaserJet 4200 Printer
How do i set the ip address on hp laserjet 2300n printer
First let me state that the network cards on these printers are notoriously bad and fail very often. Before attempting any settings, use the arrow keys to bring up the information menu and then printer a configuration. If you have a network cable plugged in then the configuraiton page will print both the basic pirnter configuration page and the Jet Direct status pages which will show the currently set network information. If only one page pirnts then the card is not working, if three pages print the card is working and you will be able to follow the instructions below.
Press the menu button and then use the up and down arrow buttons until "configure device" is shown and press the checkmark. Use the up and down arrows until display reads "EIO" jet direct menu then follow these menu options
Arrow down until display reads TCPip press check.
Arrow down until it reads enable, press checkmark and change option to yes, press checkmark.
Next arrow down to config method press check and then choose DHCP or manual and press check. If you have a router it will automatically assgin an address to your printer when you set it for DHCP, if not, you will need to select manual and then manually input IP address, subnet and gateway.
Once you select manual you will have the option to input the IP address, subnet and gateway using the arrow keys and the checkmark.
Mar 28, 2011 | HP LaserJet 2300N Printer
How to find ip address in hp 5500
To locate the IP address with the HP Designjet 5500, follow these steps below:
Press the Down Arrow keys on the front panel until the Setup Menu is displayed. Press ENTER. Go to the Utilities menu and select Test Prints.Press ENTER. For the HP Designjet 5000 series, select Service Config. Press ENTER. For the HP Designjet 5500 series, select Network-card Config. Press ENTER
Feb 12, 2011 | HP Color LaserJet 5500 Printer
I don' t know de printer' s ip address. how I can learn it? the printer is tallygenicom 8008
You can print a configuration page this will show you the current IP Address set in the printer, this Can be printed in the follwoign way;
  • Place printer OFFLINE
  • Press MENU / ENTER button
  • The display should read TEST MENU (if it does not press > repeatedly until it does)
  • Press > until CONFIG PAGE is seen.
The printer will print out a configuration page this will show the network settings
Dec 01, 2010 | TallyGenicom 8008 Laser Printer
How do you find out how many pages were printed on HP LaserJet M2727 MFP
Print out a config report, or a supply status page from the printer. under the reports sub menu. You can also access the embedded web server by typing the ip address into your internet explorer.
Al
Aug 31, 2010 | HP Laserjet M2727nf Multifunction Printer
J4167A jetdirect card not ready LAN ERROR-OPEN
if it is recognizing the jet direct card then the card should be good, not sure if yor network is setup for using dhcp but I usually deal with manual settings on these cards. I'm sure you know what your doing but it doesnt hurt to bounce it off others anyway.
I'll assume you know how to access the eio settings for the jetdirect from the menu screen.
choose manual setup instead of dhcp and keep all the othr settings at default except these other 3
1. You'll need to assign a manual I.P. address
2. you'll need a subnet mask I.P
3. You'll need a default gateway...
If you have other printers online then the subnet mask and default gateway should match the other printers but the actuall printer I.P address will of course be different... Hopefully this will help you out, and if so please write this a FixYa!!
Jul 19, 2010 | HP LaserJet 4100n Printer
I need to print off the configuration page nicludng the DHCP given IP address
When the printer is in the ready state, press the go and cancel buttons at the same time and a config page will print.
Dec 23, 2009 | HP Color LaserJet 2550n printer + HP Color...
Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Aug 08, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP LaserJet 8000n Printer Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
