Question about IBM (250410U) Docking Station for ThinkPad
My Lenovo T61 will lock up if the power is interrupted to the docking Station 2504. Right now, it is connected to a UPS but even then, if the power surges or drops out, the momentary flicker in the power is enough for the docking station to freeze the screen and freeze all inputs from the mouse or keyboard. Supposedly, the fix from 2 years ago was to upgrade the BIOS but my BIOS is already newer than the upgrade they suggested. And even then, the suggested "fix" would kill the ports on the docking station, which makes it ridiculous to have a docking station. Is there a real fix out there now? I can't find one anywhere.
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have Thinkpad T60 and
Hi.
Ensure that
Ensure that on Thinkpad you have selected between external monitor and buit in display. I think the button combination is fn+F7 check also the rest of function buttons.
Important NOTE: Ensure that video and keyboard drivers are installed, working and up to date. If video or keyboard drivers are not working you will not be able to use the external video port.
If all the above does not work, you can test the docking bay port using a multimeter set on Ohms on the contact in the two video socket portss in the docking bay. Id the connection is good there must be continuity (zero or low Ohms) in the correspondent pins between computer side and monitor side DVI socket.
Posted on Aug 27, 2010
ThinkPad T410 Docking Station Not being Recognized
Change the BIOS to reflect output through dock(external Monitor) first.
Jan 05, 2012 | IBM Lenovo ThinkPad T410 Notebook PC
Why wont iphone communicate with the ipod station
Have you made sure that there is no protective case on your iPhone that would be interrupting the connection between the two devices? Have you verified that your device is compatible with the dock? On most of the new ones they require a digital input from the iPod/iPhone which only iPods made in the past few years (2007 or later) can supply. Also try docking your device when the docking station is in standby mode.
Dec 25, 2011 | Philips DCM250 Table Stereo Clock Radio...
Docking station USB ports are not working - Laptop is Lenovo x201
I unplugged the moniter, mouse keyboard and power. I plugged in the mouse, keyboard, moniter and then the power. I placed the laptop on the docking station and it worked.
May 02, 2011 | IBM (250410U) Docking Station for ThinkPad
Similar problem here...Lenovo T61p won't power up.
Sounds like it needs the magic reset procedure. Press the power button 11 times and on the 11th time hold it for 30 seconds. Put the battery and power adapter in and retry it.
Nov 24, 2009 | Lenovo ThinkPad T61 Notebook
I have a Latitude D630 laptop and I recently purchased a docking station to use with it. I tried my laptop's PA12 Power adapter When I initially connected everything and placed the laptop on the dock an...
Try updating to BIOS to version A16 from http://support.dell.com Ensure you are not attached to the docking station when flashing the BIOS. Once updated, connect the 90W adapter to the docking station, connect your laptop to the dock, and power on using the docking station power button.
Nov 13, 2009 | Dell Docking Station for Latitude D600
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Shut down not complete from dock station
the z sometimes means sleep mode which ur laptop is still running but ur harddrive is not in motion as much as it is awake
Jul 19, 2009 | Lenovo ThinkPad T61 Notebook
T-60 will not seat properly in 2504 docking station.
I have the same docking station and I am typing this on my T60 right now. I have noticed that sometimes it is very hard to dock my laptop and other times it just slides on instantly. This seems to be an issue with poor design. If you look a the dock connector under you laptop you will notice there is a strip of plastic in the middle of two rows of connectors. The docking station connector must be perfectly aligned to successfully connect. I would inspect it for any damages, but honestly I think it is just an issue of patients, precision and a little bit of luck. If you can not identify any damage I would just slowly try to line it up and keep trying until it clicks. Remember to never force it and once it lines up it will slide in with very little force.
Nov 04, 2008 | IBM ThinkPad T60 Notebook
Blank screen
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen .
E-mail CHID: 5858 All it says is Error loading operating system on a black screen. Answer. This issue is often caused when the computers BIOS.
Read & Follow instructions/ Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Lenovo ThinkPad T61 Notebook
IBM (250410U) Docking Station for ThinkPad Logo
226 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
