Question about Microwave Ovens
I'm installing a microwave oven above stove. i know i have to run wire so it has it's own supply line and to put outlet in cabinet but not sure what size wire to run to the 20amp breaker in the panel.
  • 11 Answers
You should run 12-2 wire from the breaker panel to the new outlet box in the cabinet above the microwave.
Posted on Aug 06, 2008
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
I have a Whirlpool Velos Microwave/convection over the range microwave. It is 2.5 years old. Tonight, after putting the fan on the unit is now indicating an Error message "F2H1-Hood Keys Stuck- the...
Sounds like the pads that you push on the touch panel are stuck, will probably have to replace the whole touch panel. On units installed over the oven, they typically plug into an outlet in the cabinet above the microwave. if not, try flipping your circuit breakers until you find the one that shuts off the Microwave.
Aug 24, 2017 | Microwave Ovens
I have bought a whirlpool microwave wmh1163xvs. where does the power cord exit the oven and where should the plug in be located?
Typically the power cord on above the stove microwaves exit from the top of the oven. That way the oven can be mounted to the wall and the power cord can be routed up to an outlet in the cabinet above the microwave.
May 02, 2010 | Whirlpool MH7140XF Microwave Oven
How far out does a microhood sit from the cabinet. My cabinets are 12 inches and the microhood I want is 16 deep. Also it will be 19 inches above my stove.
Don't know right off the top of my head, but the installation instructions should tell the min and max height from the stove. If they don't you may want to contact an electrician to find out.
Mar 29, 2010 | Kenmore 62622 Microwave Oven
Need to know how to install
THERE IS EITHER OR BOTH A BRACKET THAT SHOULD BE SECURED TO THE WALL STUDS TO SUPPORT THE MICROWAVE AND THERE ARE THREE LONG SCREWS THAT GO THROUGH THE CABINET ABOVE THE MICROWAVE WITH AN OUTLET IN THE CABINET. THERE IS AN INSTALLATION GUIDELINE IN BOX. IF YOU STILL FEEL UNCOMFORTABLE HAVE YOUR SUPPLIER GET SOMEONE TO INSTALL.
Mar 10, 2010 | Kenmore 63252 Microwave Oven
How to install a electric line for over stove micowave
This is usually best left to a licensed electrician, however in some homes there is already electrical wiring over the stove for an exhaust fan. You might be able to tap into the exhaust fan wiring and install an outlet that you can plug the microwave into, or if there is an electrical outlet near the stove area you might can tap into it just be sure that you are not overloading the outlet. For example if there is a refrigerator or other major appliance using power from this outlet it might not carry enough current to operate the refrigerator and the microwave at the same time and will cause the circuit breaker to open or fuses to blow.
Sep 09, 2009 | Kenmore Microwave Ovens
Hi I'm thinking of getting an OTR mictowave and was wondering if I have to install an outlet in the cabinets or can I just place it where the existing wires for the hood fan are. This location would be...
The outlet needs to be in the cabinet above. The microwave needs a dedicated circuit. Turn the power off to the hood and see if any lights or outlets go off on the same curcuit. If only the hood is on that line your good to go with that wire if it meets requirments. Our code asks for 15 amp breaker and 12/2 grounded wire. If it meets your local requirments, just take it up inside the wall to your new outlet location(usually there is enough wire to reach) and install a box, outlet and cover.
Jul 23, 2009 | Microwave Ovens
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
Sounds easy...but
Installing one of these between two cabinets and supported by the one above it is a pain ..but even worse if you don't have the installation directions. If you are relatively handy and have some carpenntry experience, I'll walk you thru the way I install them. First off, I assume you are installing this above a stove and betwwen two wall cabinets.. You need to do a little preparation work first. locate the wall mount bracket and you should have a packet of hardware ( primarily two long screws that will be used to support the front of the micro from the cabinet above) If you have all this.. you'll need to determine if you are going to vent the micro back into the room or plan to vent it outside. The simplest is to vent it back into the rook thru a charcoal filter but if you are going tovent it outside, you have two choices.. one is to vent it up thru the cabinet and outside via ductwork that you buy..if the microwave oven is being attached to an outside wall then it is easiest to vent it straight out the back ( i say this because you have to orient the blower in teh configuration that you are planning to use) Let's assume you will be venting this back into the room ( that's the easiest ) and move on.. The wall mount bracket supports the back bottom of the microwave oven when you secure it and the two long screws will be used to bring the front of the micro up against the bottom of the cabinet above it... I normally locate the wall studs and then buy and fit a 1/2 inch piece of plywood onto the wall where the micro will be mounted. The microwave will project out 1/2 inch further as a result of this plywood panel but.. you can use lots of drwall screws to the secure the plywood to the wall studs and then you can mount the wall bracket onto this plywood without having to worry about where the studs are and if it will support the microwaves weight. Mount the bracket onto this plywood piece. I will use drwall screws and add flat washers to them to provide additional support. Once that bracket is installed, you will need to figure out how you are going to provide power to the microwave. If you are replacing an existing oven then you will probably have a power fees inside the cabinet =situated above the microwave oven. If not, then you will need to provide a power feed for this. In the old days, most of these appliances were hard wired into junction boxes but nowadays, most appliances are treated as removable and all you will need is an outlet box in the cabinet above. I suggest you bore a hole large enough for the power cord plug to fit thru the bottom of the cabinet so that you can plug it in. The next part is the hardest to accomplish.. If you look at the top of the microwave oven, you should see two holes near thhe front and on top. Those two holes have floating captive nuts inside them that the long screws ( included in your hardware kit) will be used to snug the front of the micro up against the bottom of the cabinet above it.. The trick is to measure from the back wall out to where these holes need to be drilled in the cabinet above so that they line up. You can drill bigger holes than you need and use oversize washers if necessary. If this sounds complicated ..it IS.. i have put many of these in and unless you are actually doing one, youhave no idea how involved this can be.. even worse with ducting to the outside.... I hope this gives you some tricks on how to install.. And um.. if you do get this all together, you will need some help actually putting it in place.. You'll need to catch the back of the microwave onto the tabs of the wall bracket and then feed the wire thru the cabinet while you lift the entire thing up to start the screws from the cabinet down onto the top of the microwave. I'm a big guy and have done these myself but it is not easy.. Hope this helps you.. Lastly, here is a link to the GE website where you can download the user manual and search their FAQ for install details ( in retrospect, I just should have given you that info).. http://www.geappliances.com/service_and_support/literature/
Hope this helps you...
Sep 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need help figuring out microwave installation above stove
Not sure I understand the question, but is building your own cabinet or enclosure an option?
If not, please feel free to write us back if you can clarify this matter further.
We'd be happy to help.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
106 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
