Question about Refrigerators
General eletric freezer model # CB6DPB problem: it is un plugged and still leaking water. there is no water inside. whats happening?
SOURCE: leaking fridge
Its probably the defrost circuit either the heater or the timer
Posted on Oct 30, 2007
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
jtbjtb
  • 135 Answers
SOURCE: Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Posted on Jan 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Posted on Aug 13, 2009
heatman101
  • 43501 Answers
SOURCE: water leak from freezer side
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 15, 2010
How to remove evaporator cover from inside freezer admiral model hmg64184
Hello Joann Carter,
Make SURE you are electrically UN-PLUGGED.
The repair books tell you to remove all the side rails... pull the screws... Disconnect the temp sensor (if equipped in this area (here you want to start taking lots of pictures))...
The thing is... removing the side rails is usually un-necessary...
A little clever negotiating of the flexible panel... and it can be MANUVERED AROUND (my opinion)...
Further opinion... after a complete open air defrost
(never apply heat (anywhere))... FANS will help... It is possible to blow air UP the defrost drain... & clear it.
Again... Verify you are electrically UN-PLUGGED.
Then negotiate some warm water (never hot) into the
Evaporator-drain pan... Success will be immediately
apparent in the defrost pan...
May take a couple of tries... (straw or flex tubing).
Only failing that... pull out the back panel .
Hope this helps!
Aug 21, 2016 | Maytag Admiral 26 cu. ft. Side-By-Side...
Where is the drain located on Frigidaire model r134a? is it the hole on the bottom freezer side?
R134A is not the model number. This is located inside the freezer on a white sticker on the left or right wall. Anyways, the drain is going to be located inside, behind the back wall of the freezer on the floor, directly below the Evaporator coils where all of the "cold" in your entire box is created. If you're referring to a refrigerator, there should be an aluminum tray/pan that all the defrost water drains down into. Sometimes they just freeze over & the hole becomes plugged w/ice. Hope this helps. Tips appreciated. Have a great weekend :)
Mr. All-Star
Jul 30, 2016 | Frigidaire Refrigerators
Ad 18
Three things come to mind:
A) High humidity has overwhelmed the defroster & blocked the passageways so air will not circulate. (Put important food in a cooler, turn the temperature dial to off & leave doors open until ice melts out. Generally overnight. Be prepared to mop up excess water)
B) Defrost timer stopped working. (Generally behind a cover panel on the fridge side. Un-plug unit & remove panel to find a small metal box in the airflow path from the freezer. They generally have provision to manually turn the timer wheel with a screwdriver. Plug back in & allow to run & see if the ice melts. If so, the clock motor is shot. Replacements can be bought on-line)
C) Burned out defroster heating element. Generally older units. (Un-plug & put essentials in a cooler. Remove cover panel on freezer side to expose cooling coils. Allow ice to melt overnight, (again, lots of water). In the AM you can see the glass tube enclosed heater coils. All dark & smokey inside, heater is burned out. Replacements on-line for ~ $75.) If the unit is more than 15 years old, consider a more energy efficient replacement.
Good Luck!
Jun 29, 2013 | Kenmore Refrigerators
Ice build up bottom of freezer compartment and water leaking from un der the refrigerator i think maybe a drain is plugged and how do i fix it. and the model #mzd2766gew
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing.By pulling the ref. from the wall there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps,
Gene
Aug 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Water coming from freezer into refrigerator otherwise appears to be working ok
I will try to give you a better idea of how and why this happens. The problem is that every different model has a different way of leaking. Like a side by side if the defrost condensate drain line is blocked the water will at most leak inside freezer. With a single top freezer the water may just leak down into the fresh food section. Click Here=> Leaking Refrigerators Just What may Be HappeningThanks, Sea Breeze
Jan 10, 2011 | Roper Refrigerators
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
Model 106-74269401 mfg date 6/05. Constant pool of water on interior top shelf leaking from freezer above. What is standard repair?
That is most likely the defrost condensate pan inside the freezer has frozen over and closed the drain opening. Once that happens then the water has no where to go but the freezer or the fresh food compartment. Below is a link to different ways of this happening. Just choose the section that resembles your refrigerators problem. The water freezing over does not always need to go to the extreme measure to prevent it. It's possibly something blocking the line between the freezer and the pan under the refrigerator. Let me know what you find, Thanks, Sea Breeze
click on link
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 19, 2009 | Kenmore Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
My freezer is leaking inside the freezer area. I took off the panel on the inside and can see that it is leaking by the top of the coils. The water then freezes at the bottom of the freezer. Again all this...
This water comes from the defrost cycle. The drain hole is probably plugged with food. The drain usually goes to a small pan under the condenser where it eventually evaporates. Look for a hole or slot in the bottom of the unit.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
