Question about Logitech Audio Players & Recorders
The audio from my logitech x-530 speakers will not connect through my 42" vizio flat screen. What do i do?
  • Logitech Master
  • 27,725 Answers
Make sure you have the correct speakers selected
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 08, 2011
How do I connect Logitech x-530 speakers to my Akai flat screen tv model no: LCT2016
You can only connect two stereo speakers to the TV. You need to consult your user manual.
Mar 23, 2015 | Logitech Audio Players & Recorders
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
How do i connect Logitech X-530 to my TV?
Connect the audio cables (red to red, white to white) from the audio out on the back of your TV to the audio in on your speaker system.
Feb 22, 2010 | Logitech X-530 Computer Speakers
How to connect logitech X-540 to LG 42
Hi, You should have an Audio outpout RCA behind your TV. Plug it 2 RAC then the cables to an RCA/ 3 mini JACK adapter. Plug the 3 mini jack to the X-540. You have your audio output settled up on your X-540. Thanks and have a nice day !
J -
Jan 23, 2010 | Logitech X-530 Computer Speakers
Only two speakers are working I have vista ultimate install in my computer , I have logitech X-530 speakers
Helllo there!
You have to make sure you have in control panel your audio sound card, well installed and is working right. Then go to control panel and see your speaker configuration, is suppose to be at 5.1 speakers also you can use 6.1 Speaker configuration. Be sure you connect right your speakers at back of the audio jacks!
that's it!
good luck!
Open Sky
Dec 08, 2009 | Logitech X-530 Computer Speakers
Hello, Currently I have Vaio laptop connected to my Vizio 42" inch flat screen TV. There's no audio coming from my Vizio TV. So I connected an audio cable connected to the stereo jack. Where do I connect...
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
How do i conneect logitech speaker to a vizio flat screen?
Well these speakers, as you said, are designed for PC, not TV. Even if they work with one TV, that does not mean they will work for another TV! I am glad to help for a Premium Question!
Mar 02, 2009 | Logitech X-530 Computer Speakers
X-530 with LCD Vizio TV
you need to go to radio shack and buy a y plug to be connected between tv and computer. unless i miss understand you...
Nov 05, 2008 | Logitech X-530 Computer Speakers
LOGITECH X530
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Aug 11, 2007 | Logitech X-530 Computer Speakers
37 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
