Kingston RAM vs Elixir RAM need to upgrade ram on laptop!... which one should i go for? If you can give pros/cons please!.. (more interested in which is stable...and less likely to fail)
antiochpc
  • 1314 Answers
SOURCE: replace ram in laptop compaq v5201us
Okay.....go to www.crucial.com and figure out what RAM you need to purchase. It will tell you what you need. Then, once you get your memory, unscrew the screw on the bottom of your notebook that covers the RAM and either replace or add the new memory that you just purchased.
Posted on Jun 14, 2008
SOURCE: Compaq nc8230 Ram Upgrade
Do a search on this website for nc8230 manual. I just did and found the complete manual loaded with hyperlinks. Follow the step by step instructions and you will find the process relatively straight forward. Essentially what you need to do is loosen a couple of screws in the back, remove the keyboard then remove a plate underneath which will expose the ram module.
Make sure you read the manual though.
Cheers
Posted on Jul 25, 2008
hokuwho
  • 306 Answers
SOURCE: Diff between SDRAM and DDRAM
Only one of those will work in any computer. Synchronous Dynamic Random Access Memory is older and slower, Double Density Random Access Memory is faster and DDR2 is newer. The notch in the connector edge will not match the RAM slot if you have the wrong one. Also the DDRAM has various speeds to match the bus speed of the motherboard so designators like PC2100, PC2700, PC3200, etc. are important and correspond to 266MHZ, 366MHZ, 400MHZ, and so on. Notebook use SODIMM RAM and have the corresponding DDR, DDR2 designators but still have notches that must match the slot. When you buy RAM just provide the model of your computer as each manufacturer has numbers that are all designed to confuse it seems and there may be no chance of exchanging the memory after you open the package. Steve
Posted on Oct 16, 2008
frcs68
  • 1605 Answers
SOURCE: comparison amd turion x2 64 bit vs core 2 duo
x2 64 bits is faster, however, there not much of software support at this time.
2 duo is 32 bits. there are plenty of software.
you will not know the difference unless you are playing on line game.
wh don't you spend the mony on the memories.
Posted on Oct 28, 2008
lorenzo_most
  • 60 Answers
SOURCE: upgrade ram on HP LAPTOP COMPAQ NX9010
Ok, so you just got more Hard disk space, or a new bigger Hard disk. Of course you need t upgrade the Ram memory. This computer supports Ram memory up to 1 Gb with a max frequency of 266Mhz. You probably have 256Mb or 512Mb of Ram Memory. You can go to any computer store and get it upgraded. It shouldn't be expensive. But don't forget :
Use this tyoe of RAM: DDR SDRAM (266 MHz), Upgradeable to 1GB
By the way, even after the upgrade, I advise you to run a Defrag of your Hard Disk and clean all your temp files.
There is a free and easy software to clean all temp and internet temp files: Ccleaner.
Posted on Apr 01, 2009
How to take out memories out of your computer or notebook PC?
on a desktop computer, the RAM memory is attached the motherboard in 3 or 4 slots.
On a laptop, notebook they are hidden under a small cover on the bottom. The also fit into slots, but at in line with the case.
  • Laptop Memory Upgrades - Kingston.com‎
    Adwww.kingston.com/Memory
    This ad is based on your:
    • current search terms
    • recent searches on Google
    Visit Google's Why This Ad page to find out more, block specific advertisers or opt out of personalised ads.
    Kingston has the right memory for your PC/Laptop. Lifetime Warranty.
  • .spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
    g-img{display:block}._WCg{display:block;border:0;position:relative}
    Search Results
    How to Upgrade Laptop RAM and How to Install Laptop ...
    2q==? 2:43
    https://www.youtube.com/watch?v=pcBwnb8rENQ
    Oct 4, 2013 - Uploaded by nickscomputerfix
    Watch hands on laptop memory installation on my Acer l... ... Upgrading Your Old Laptop: Replacing RAM and ...
    How to Add RAM to Your Laptop ' PCWorld
    www.pcworld.com/article/.../how_to_add_ram_to_your_laptop.html
    You can significantly improve your laptop PC's performance by adding RAM, ... Tools: To replace or upgrade your memory, you'll need (at minimum) a good ...
    How to Upgrade the RAM (Memory) on a Laptop - Laptop Mag
    www.laptopmag.com/articles/ram-upgrade-tutorial
    Sep 4, 2014 - Here is a step-by-step tutorial (with photos) on how to find the correct RAM upgrade for your laptop and how to physically install the memory.
    How to Install RAM in Your Laptop - For Dummies
    www.dummies.com/how-to/.../how-to-install-ram-in-your-laptop.html
    The general process of installing memory modules, or RAM, in a laptop is very ... Replace the memory compartment cover and lock it down with the screw.
    Mar 04, 2016 | Computers & Internet
    My laptop become very slow ...its 1 gb ram and 160 gb harddisk .... which os i should install please advise
    You need to upgrad the amount of RAM.
    The 4720 notebook is capable of running up to 4GB or ram on 32bit windows 7 OS
    The OS requires 1GB of RAM to run.....
    Therefore, you only have enough RAM to run window, and no spare ram that should be dedicated to the graphics and other system operations.
    Action needed:
    Buy 2x 2GB sticks of Kingston ValueRam and run the laptop on 4GB. It will be much faster than what is needed and should provide fast computer responce.
    Cheers.
    Dec 06, 2014 | Acer Aspire 4720 Notebook
    Laptop currently has three 4GB RAM sticks, is it possible to use another 8GB stick to upgrade it to 20GB?
    It should. But RAM slots have a maximum RAM per slot. Have you checked with manufacturer manual to see what the max ram per slot is? And the max ram per motherboard matters too. Your mobo will only support so much ram.
    Dec 07, 2012 | MSI Gt70 0nc-051us
    I recently purchased 2 1gb pny ram ram sticks hoping to upgrade my ram. After installing the 2 sticks the computer doesnt boot. I reinstalled the original 2 512mb sticks and the computer works fine. Is my...
    Without the computer model and make I can't say if it is upgradable or not. Most are upgradable to some extent. You will need to look for the product description of your laptop on the manufacturer website you may want to download the user manual from them or check the manual you have if you still have it. Yo9u are looking for the max ability of the computer and at the speed and type requirements for your ram. Also, you should know that some companies make Ram of the correct type and class but for some reason will not work in some models. I have Kingston ram 2gb modules that will not work in my Laptop but I purchased Siemens Ram of the same type and it works fine. So it may just be a matter of Ram Manufacturer.
    Jan 14, 2011 | Computers & Internet
    Trying to upgrade memory in a toshiba satellite a105 s1013
    Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
    http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
    Feb 14, 2010 | Gateway MX3215 Notebook
    Ram upgrade problems
    looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
    but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
    Nov 03, 2009 | ASUS Eee PC 900HD Netbook
    1. Has anyone installed 2Gb RAM memory in a Sony PCG-TR3A? please give details of memory specification. 2. Has anyone installed a HDD bigger than 40GB? please give me details of HDD specification.
    You can only upgrade the memory to 1GB in that model Vaio laptop.
    The memory supported is DDR SDRAM which runs at 333MHz. There are 2 memory slots which support 1x512 module in each slot.
    I recommend Kingston RAM as the manufacturer.
    As for the HDD the laptop supports EIDE (IDE/ATA) hard drive. you can have anything up to 320GB. Seagate are excellent drives as well as Fujitsu.
    Regards.
    Sep 29, 2009 | Sony PCG-TR3A Notebook
    Change 1gb ram to 2gb ram in laptop
    Go to any computer accoseies shope and buy a kingston 2 GB DDR2 ram for your laptop
    Apr 03, 2009 | Toshiba Satellite Pro L300 Notebook
    RAM vs BIG 7200GS Graphics card
    ur graphic card might not b compatible with ur motherboard.. check the compatibility list in the user manual of ur motherboard
    Jan 30, 2009 | Asrock P4I45GV R5 Motherboard
    Conflicting information about maximum memory allowed
    Your problem is not so clear. I guess you are having a P-4 with MSI Mother board. Almost all motherboards that support DDR 333/400 can support up to 2 GB of memory.
    It is always better to buy brands like kingston.
    Sep 12, 2008 | Evesham Axis PC Desktop
    Computers & Internet Logo
    311 people viewed this question
    David Payne
    David Payne
